Conformal coating inevitably affects capacitance, but it will also affect resistive leakage if you don't apply it carefully. You need to have a really clean board, thoroughly dried, before applying the coating. If you don't you will trap moisture under the coating, which has a nasty tendency to be a lot more leaky than the surface moisture was before coating.
