I see nothing special with it, apart from the fact it's a dual NMOS with the two drains internally connected.
You can do the same with any dual MOSFET that doesn't have its two drains internally connected, just connect them externally.
So likewise for a PMOS version, select any dual PMOS with proper characteristics and connect their sources externally if they aren't internally?
