Author Topic: OT Rosetta arrives at comet  (Read 34569 times)
Offline Wh1sper
    • Zockertown
Re: OT Rosetta arrives at comet
« Reply #25 on: August 08, 2014, 12:41:24 pm »
Uses a stack and RPN arithmetic logic like the programmable HP calculators of that period.  :-+
My long standing favorite Language!
(ago)
Offline miguelvp
« Reply #26 on: August 08, 2014, 07:13:42 pm »
I'm pretty sure compilers always generate RPN code when they encounter formulas, it wouldn't make sense to do it a different way.
Offline jaxbird
« Reply #27 on: August 08, 2014, 07:27:49 pm »
I find it incredibly impressive to have a space craft doing a 10 year journey to orbit and possibly land on a comet, while the comet is travelling at incredible speeds around our sun!...
Truly amazing in my book, I'd rather we spent a much larger budged on science and space exploration that currently. It's the future, it's worth the money!
Analog Discovery Projects: http://www.thestuffmade.com
Youtube random project videos: https://www.youtube.com/user/TheStuffMade
Offline bwat
    • My website
« Reply #28 on: August 08, 2014, 07:49:11 pm »
This isn't really applicable in this case. The microprocessor in question has a stack architecture - it's essentially a FORTH microprocessor - it's ALU instructions don't take specific operands as the operands are on the data stack. The machine basically has a type of FORTH as it's assembly mnemonics. This is from Koopman's book I linked to earlier and it has the instruction set:  http://users.ece.cmu.edu/~koopman/stack_computers/sec4_5.html.
As for compilers in general, there's no need to generate RPN code if you've got a typical accumulator architecture or a general purpose register architecture. Say you had a typical RISC machine with 31/32 registers, then you would do this:
adi r3, r0, 99      ; r0 contains 0, so r3 <= 99
adi r4, r0, 98      ; r0 contains 0, so r4 <= 98
add r5, r3, r4      ; r5 <= 99+98
and not something equivalent to this which needs a data stack and potentially memory accesses if the stack is not on the chip:
LIT 99
LIT 98
PLUS
[EDIT: I've realised that when you write RPN you're meaning the order of evaluation, i.e. evaluate the operands then perform the operation. When I read RPN I think stack plus zero operand instructions. Actually, it's syntax not semantics. Anyway, if I'm right in my assumption about what your interpretation is, then you're correct as the arithmetic operation will have its operands evaluated before the operation takes place - even in a non-strict functional programming language.]
« Last Edit: August 08, 2014, 08:18:34 pm by bwat »
"Who said that you should improve programming skills only at the workplace? Is the workplace even suitable for cultural improvement of any kind?" - Christophe Thibaut
"People who are really serious about software should make their own hardware." - Alan Kay
Offline miguelvp
« Reply #29 on: August 08, 2014, 08:25:21 pm »
I was thinking more of floating point processors, where you do fld to load the values and then do the operation. All the ones I've seen are stack based.
Offline Alexei.Polkhanov
« Reply #30 on: August 09, 2014, 04:55:47 am »
I look at few pages of that book - only ones shared by Google and what surprised me, somewhat is that book describes use of components in BGA (Ball Grid Array) packages. I was under impression that BGA would be too risky and not reliable enough for space applications comparable to one of those gold lead ceramic QFP packages. Don't want to get red circle of death on your $1B space toy.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #31 on: August 09, 2014, 04:37:53 pm »
It's my understanding, BGA is more reliable per-pin than QFPs.  And you can get a hell of a lot more pins down...
They also use leaded solder, not the stuff prone to cracking.  Though the higher strength of RoHS processes tends to lead to higher reliability anyway; it seems tin whiskers were much ado about nothing after all.
Seven Transistor Labs, LLC
« Reply #32 on: August 09, 2014, 06:08:20 pm »
Well it is strange. Why spend ll effort to make components in "military packages". I mean those pinkish ceramic QFPs with gold leads, extended temperature ranges etc. and then use BGAs. I am not an expert in designing hardware for space applications but there is definitely huge temp variations, absence of air/gas that allow for heat transfer, vibration during launch that can knock your teeth out and then on top of that radiation. And yet we have BGA-related problems in room environments.
I have heard (or watched in some video) that sometimes BGA component sort of under-filled with epoxy. It have to be very thin runny epoxy to be able to squeeze it in between soldered balls. I have seen it done on one board from cable modem. Is this something I can buy from DigiKey? Just curious.
Offline KJDS
    • my website holding page
« Reply #33 on: August 09, 2014, 07:02:16 pm »
Every BGA will have been xrayed from a few different angles. It becomes very obvious if a joint isn't good.
Offline T3sl4co1l
« Reply #34 on: August 09, 2014, 07:46:42 pm »
A shittily engineered product is a shittily engineered product... what do you expect?
Examples of consumer use:
Plop down a footprint either from the manufacturer's suggestion, or IPC guidelines.
Solder in standard reflow.
Ship product.
Whereas aerospace may go back all the way to the footprint to optimize geometry for their process; the board material TCE can be matched to that of the device (I've seen it in IPC books but never IRL: there are PCB materials with rigid metal supporting cores to control CTE and such -- this isn't your average aluminum PCB), and the solder alloy, flux and reflow profile can all be optimized for best reliability.  Test data is generated from accelerated life and vibration testing, presumably with a margin beyond the (already severe) stresses of launch or whatever.
Offline TerraHertz
    • It's not really a Blog
« Reply #35 on: August 11, 2014, 02:31:52 am »
Meanwhile, more pics:
http://www.esa.int/Our_Activities/Space_Science/Rosetta
http://www.esa.int/Our_Activities/Space_Science/Rosetta/Highlights/Postcards_from_Rosetta     Latest images
My favorite so far:
Considering the comet is about 4Km in some dimension, and that view is kind of looking 'down' towards the center of gravity, it gives me that aching-fingertips climbing risk-exposure feeling. At least if you fell there, you'd have a long time to wonder how much your impact was going to hurt. Also, you'd get a number of preview impacts on the way down.
Thanks for the link to the Forth-CPU book.
Offline firewalker
  • Country: gr
« Reply #36 on: November 10, 2014, 08:14:15 pm »
One day to go.
Rosetta will deploy Philae on November 12 at 12:35 AM PST. Confirmation of the landing will arrive at ground stations around 8:03 AM PST.
Alexander.
Offline German_EE
« Reply #37 on: November 10, 2014, 08:39:32 pm »
16:00 UTC or 17:00 CET for those of us in Europe (Mission Control at ESOC are about thirty minutes walk away from me).
Warren Buffett
Offline JoeN
  • We Buy Trannies By The Truckload
Have You Been Triggered Today?
Offline Kjelt
« Reply #39 on: November 10, 2014, 10:08:06 pm »
So what is the gravity on that thing? Will it attract enough to keep on standing on it or if you jump you will float into space?
Offline Frost
« Reply #40 on: November 10, 2014, 11:42:20 pm »
The gavity 1:100.000 compared with the earth.
The weight of the lander Philae is 100kg here on earth
but it only 1g when Philae lands on the comet.
No, it depends on the unknown underground if its to dense
the lander might jump back into space.
But they use a gas jet to force Philae to stay on the ground
as long as they need to apply the harpoons and the self-drilling
anchors.
Offline EEVblog
« Reply #41 on: November 11, 2014, 12:27:25 am »
Aussie systems engineer gives it a 50% chance of touchdown success
http://www.abc.net.au/science/articles/2014/11/10/4123194.htm
Offline DJohn
« Reply #42 on: November 11, 2014, 11:41:04 am »
Sorry, this is an old post, but I've only just seen it.  The only stack-based floating point I know is the old x87.  It still survives in modern x86/x64 processors, but compilers will try to use the register-based SSE instructions instead (for single precision at least, which is all I usually care about).
Floating point in everything else I've used (MIPS, PPC, ARM, 68K, vector processors from various Playstations, GPUs) has been register based.
Offline Kjelt
« Reply #43 on: November 12, 2014, 08:30:25 am »
In the newspaper today it said 25% chance on failure esp. possible tumbling of the Philae lander, that would be 75% chance on success.
Well in 8 hours we will know, keep our fingers crossed.
Impression of how it should look best case
Offline Homer J SimpsonTopic starter
« Reply #44 on: November 12, 2014, 02:57:38 pm »
Offline Kjelt
« Reply #45 on: November 12, 2014, 03:44:05 pm »
or here:
http://rosetta.esa.int/
still 15 minutes to wait till we know if it succeeded or not
Offline KJDS
« Reply #46 on: November 12, 2014, 04:04:55 pm »
cheers in the control room
Offline Kjelt
« Reply #47 on: November 12, 2014, 04:06:48 pm »
Yeah  they look happy still waiting official words
Offline Kjelt
« Reply #48 on: November 12, 2014, 04:08:06 pm »
they are receiving telemetry data, if it would have bounced off this would not be the case (what I can understand from the discussion).
Offline bookaboo
  • Country: ie
« Reply #49 on: November 12, 2014, 04:09:54 pm »
Thanks for link, all looking good.
"Sitting on surface, talking to us"
