Author Topic: optical fibre cables  (Read 1131 times)
Offline legacyTopic starter
« on: June 07, 2019, 04:24:03 pm »
I am a bit confused at the moment. The datasheet of my optical transreceiver says I need a 62.5um multimode cable with an LC connector, while the HBA needs a 62.5um Multimode SC Duplex Cable, so I need to buy a "LC to SC  62.5um patch".
What makes me confused is the offers I find on Amazon. Some say 62/125um (e.g. 3M P/N GCFA1CLM03-M), and it's ok, but some say 50um ... so  :-//
Offline jc101
Re: optical fibre cables
« Reply #1 on: June 07, 2019, 05:37:08 pm »
For multimode fibre the older standard is 62.5/125 in size with more modern standards based on 50/125.  Does anything mention OM1, OM2, OM3 or OM4 as that defines the spec?
For 99% of kit a 50/125 will work fine in place of a 62.5/125 cable.  You will probably find way more 50/125 available these days.
For the various types see here https://en.wikipedia.org/wiki/Multi-mode_optical_fiber
I'd just get an OM3 or OM4 patch lead with the connectors you mention and all should be fine.
« Reply #2 on: June 08, 2019, 10:49:27 am »
thanks for your hints  :D
unfortunately no. I have just checked and found that
- SC to LC are available with 62.5/125, rare but I can find some
- SC to SC are available with 50/125, haven't yet found one with the 62.5/125 spec
SC to SC is for a different project and needs to link two QLA2xxxF HBA.
I cannot see, in this case, what Qlogic recomends for the optical cable.
Offline jc101
« Reply #3 on: June 08, 2019, 12:01:12 pm »
I’d just get the 50/125 regardless. The generic term multi-mode is basically just all 50/125 these days.
« Reply #4 on: June 08, 2019, 12:06:42 pm »
Ok, let's try it  :D
« Reply #5 on: June 08, 2019, 01:26:57 pm »
OK, I have just purchased a couple of patch cables, 50/125. Let's see if they will work.
The manual of the HBA says only this
SC-style connector that supports non-OFC, multimode fibre optic cabling using 1x9 fibre optic transceiver module.
It's completely unclear if the transceiver uses a LED or a LASER, etc, and there are no other recommendations for the optic cabling.
Anyway I am 100% sure, this engine won't go faster than 10Gbs. It's not required, so OM1 "should" be OK.
Offline madires
  • A qualified hobbyist ;)
« Reply #6 on: June 08, 2019, 02:40:29 pm »
62.5µm multimode fiber is obsolete for quite a while. You can use 50µm MM if you don't need the maximum distance supported by the transceivers. Please see http://www.thefoa.org/tech/fib62-50.htm for some info about losses involved.
« Reply #7 on: June 08, 2019, 04:48:08 pm »
Yup, for my application, the cable's length is 50 meters.
So 50um is OK!
