You better skip the TDS600 series. Short memory an no peak detect. Better look for a good deal on the TDS500 or TDS700 series. The particular one from the listing is showing a copyright notice from before 1995 which means it almost certainly has leaking electrolytic capacitors which need to be replaced. The good thing is that the leaking capacitors have not caused a failure in the power-on diagnostics. If there are more than 2 power-up diagnostics failures on a TDS500/600/700 series it means the leakage has caused serious damage and chances are high you'll be looking at a lengthy repair job.
