Quote from: EEVblog on August 20, 2019, 11:14:59 amQuote from: coppercone2 on August 19, 2019, 07:59:57 pmDisarmed means a military technician needs to do something physically to turn it on. You would need to send an astronaut along with it to insert a core for it to be considered disarmed. Not so. There are a few reliable methods to remotely "activate" a bomb that don't require a human.One method used in real weapons is a neutron-absorbing chain or wire that is would out of the core by a motor that is remote triggered. Once the chain/wire is removed the core is "armed". The bomb can't go critical with the neutron absorber in place.thats like putting a interlock that can be remotely triggered. I would argue that you need a telepresence with a skilled human operator using a finicky robotic arm, that is all just adding 1's and 0's to stuff, as soon as you put a motor to unscrew the thing poisoning the core, IMO its armed because a malfunction can arm it. But even that is not kosher..
