When you blow it do so from the air outlet, you will get a huge cloud at first then the fan will spin again.
I took a old gas cylinder and rejigged it so I can store compressed air in it to blow out where the compressor is not available. Works well, though you only have limited volume, so use wisely and use a nozzle as well to get high velocity air that drags ambient along to boost volume.
