Author Topic: Nondestructive misuse of capacitors competition  (Read 272 times)
MarkL, JMK, SingleBitError and 5 Guests are viewing this topic.
Offline RoGeorgeTopic starter
« on: Yesterday at 04:25:34 pm »
Anybody in the mood for a competition?
The rule is to post your project in the https://www.eevblog.com/forum/projects/ then link to it here.
Get creative, because anything goes.  The prize will be as many Internet points as you can carry.
Open until first day of 2025.  What do you say?
Online I wanted a rude username
  • ... but this username is also acceptable.
Re: Nondestructive misuse of capacitors competition
« Reply #1 on: Yesterday at 04:34:51 pm »
What are the rules? Any non-traditional use of a capacitor, as long as it doesn't lose its ability to capacitate?
Offline The Soulman
  • The sky is the limit!
« Reply #2 on: Yesterday at 04:35:47 pm »
We'd need a better definition of "misuse" would that include using it (without damage):
*Beyond maximum ratings
*As a mechanical device
*In a clever but unconventional way
« Reply #3 on: Yesterday at 04:55:30 pm »
Anything goes, don't want to exclude or limit the fun in any way.  Though, a capacitor that is filtering the mains ripple after a bridge, or separating the AC from DC between two stages, most probably won't win a competition about capacitors misuse.  But what do I know?
If it gets particularly interesting, or if it comes with a twist, even the most common way of using a capacitors may win.
« Last Edit: Yesterday at 05:04:29 pm by RoGeorge »
The following users thanked this post: The Soulman
Online temperance
« Reply #4 on: Yesterday at 05:05:15 pm »
Capacitors can be used as spacers.
Edit: of course they also provided decoupling.
« Last Edit: Yesterday at 05:46:52 pm by temperance »
« Reply #5 on: Yesterday at 05:08:36 pm »
+1  :-+
Online Zoli
  • Grumpy old men
« Reply #6 on: Yesterday at 05:18:21 pm »
Capacitors can be used to decorate ceilings.
Offline ebastler
« Reply #7 on: Yesterday at 05:46:27 pm »
Use a large electrolytic cap as mechanical mounting point to support your ferrite antenna.  :)
The following users thanked this post: RoGeorge, Geoff-AU, I wanted a rude username
Online temperance
« Reply #8 on: Yesterday at 05:54:38 pm »
Class II capacitors with their DC bias dependent capacitance to replace a "varicap diode". Y5V capacitors will provide the largest tuning range.
« Last Edit: Yesterday at 05:57:40 pm by temperance »
The following users thanked this post: nctnico
Offline Infraviolet
« Reply #9 on: Yesterday at 11:12:16 pm »
Just making a guess, but might someone be able to come up with a circuit exploiting the polarised nature of electrolytic caps. It is my understanding (I generally stick to ceramics to avoid having to worry about the exact details of this, so don't consider what I'm about to say as being in any way certain...) that reverse voltages on an electrolytic should not harm it provided they are very small and that the maximum possible backward current is kept very limited by large series resistors.
Online DavidJRobertson
  • Country: scotland
    • davidr.me
« Reply #10 on: Today at 01:00:50 am »
One of the products I've worked on uses some unconnected SMD electrolytic caps as spacers in a board stack. The part was already used elsewhere in the design and cheaper than 'proper' mechanical standoffs.
