The fan runs constantly. The manufacture did create a new firmware to cycle the fan when the SCRs start to heat up. The problem is I can't find a compatible micro SD card to do the update.
I wasn't having a problem finding first gen 2GB SD cards. Finding a first gen micro SD card is the problem.
Might want to try a micro SD to full size SD adapter (opposite of the usual type), once commonly used with Raspberry Pi.
