Author Topic: Old BMW CAR WITH TURBOJET ENGINE !!!  (Read 2401 times)
Offline Free_WiFiTopic starter
  • https://tinyurl.com/y5nhpt2x
« on: August 26, 2018, 11:51:00 pm »
I do not understand the guy in the video,but i really like to watch how he's bmw is running on an miniature turbojet engine  :-+
Offline Brumby
Re: Old BMW CAR WITH TURBOJET ENGINE !!!
« Reply #1 on: August 27, 2018, 12:38:38 am »
Chrysler had their own ideas in the 1960's that didn't sandblast vehicles behind....
Offline amyk
« Reply #2 on: August 27, 2018, 05:31:02 pm »
The main advantage of turbine engines is power to weight ratio, which is why they're used in planes. Fuel economy is horrible.
Offline Brumby
« Reply #3 on: August 28, 2018, 05:36:39 am »
Not in the air when applied to a per passenger rate.
« Last Edit: August 28, 2018, 05:42:04 am by Brumby »
Offline Kleinstein
« Reply #4 on: August 28, 2018, 05:45:24 am »
In modern turbines fuel economy is not that bad - it can be actually pretty good, but those are large ones for small fast starting power plants. I don't know about the small ones. Still they use turbines in turbo prop planes, so efficiency should not be that bad.
Another problem with turbine engines is that they are relatively slow in reacting to power changes. So likely less responsive than an old diesel engine, though better than steam power.
An advantage of a turbine is that if well made there are little vibrations and a long service life is possible.
There is a small chance we might see the idea of a turbine engine in a car again, as a range extender / generator in a hybrid. This would also save the gears to bring down the high RPM down to a street level.
Offline filssavi
« Reply #5 on: August 28, 2018, 05:52:56 am »
The problem with turbines in car applications is that they are quite efficient at rated power,but when throttled back the efficiency figure take a nose dive off a cliff, now for aircraft use where most of the cruise is at a fixed speed that is fine, for a car it’s not the case
Offline julianhigginson
« Reply #6 on: August 28, 2018, 06:27:04 am »
Looks awesome for dealing with tailgaters!
Offline Brumby
« Reply #7 on: August 28, 2018, 06:50:55 am »
(Mental image of full afterburner  ;D   >:D )
Offline CJay
« Reply #8 on: August 28, 2018, 09:40:03 am »
Bit late to the party...
https://en.wikipedia.org/wiki/Rover_JET1
Online RoGeorge
« Reply #9 on: August 28, 2018, 10:04:57 am »
Half-century earlier...  ^-^
1910 Coanda Snow Sleigh for Grand Duke Cyril of Russia
https://en.wikipedia.org/wiki/Coand%C4%83-1910#Related_developments
« Last Edit: August 28, 2018, 10:12:22 am by RoGeorge »
Offline CJay
« Reply #10 on: August 28, 2018, 10:38:01 am »
Well well, learn something new every day, I'd never heard of that, it's not a car though
Offline Brumby
« Reply #11 on: August 28, 2018, 01:08:05 pm »
In March 1950, Rover showed the JET1 prototype, the first car powered with a gas turbine engine, to the public.[3] JET1, an open two-seat tourer, had the engine positioned behind the seats, air intake grilles on either side of the car,[4] and exhaust outlets on the top of the tail.[5] During tests, the car reached a top speed of 88 mph (142 km/h).[citation needed] After being shown in the United Kingdom and the United States in 1950,[6] JET1 was further developed,[7] and was subjected to speed trials on the Jabbeke highway in Belgium in June 1952,[8] where it exceeded 150 miles per hour (240 km/h).[9] JET1 is currently on display at the London Science Museum.
Hmmm.... Seems a bit suspicious...!
Offline CJay
« Reply #12 on: August 28, 2018, 02:00:48 pm »
Nah, not suspicious at all, it was only 1.20GW at the wheels.
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #13 on: August 28, 2018, 08:13:37 pm »
Just a hint to get this off ground: Try a Turbomeca Arriel 2D (850HP helicopter turbine).  >:D
Offline Augustus
« Reply #14 on: August 29, 2018, 01:08:46 pm »
Now watch this guy... Next level mama  :-DD
Greetings from the Black Forest, Germany
