Author Topic: Odroid - anyone got an opinion on these?  (Read 1223 times)
Offline wilfredTopic starter
« on: December 19, 2012, 07:55:02 am »
« Last Edit: August 22, 2018, 01:49:32 am by wilfred »
Offline peter.mitchell
Re: Odroid - anyone got an opinion on these?
« Reply #1 on: December 19, 2012, 09:45:51 am »
eMMC is basically just NAND + a controller in a single for simple interfacing and management.
In the case of this specific device, they do not provide on board storage, but they offer the next best thing; a header for attaching what would be used as on board storage in a marketed device so it would be interfaced the same way ect.
They also provide a microSD slot.
Pros of this device, the chip is a beast in its class, very good performance, though, depending on what you're emulating it may/may not be sufficient.
Cons: This is a pretty obvious software dev board, so don't really consider doing hardware dev. I'd need more info on what you're looking to do with it to give you more info.
« Last Edit: December 19, 2012, 09:52:46 am by peter.mitchell »
