Author Topic: Multi-Tool for DIY electronics  (Read 18805 times)
Offline BokononTopic starter
« on: July 24, 2011, 12:26:20 pm »
What do you think is a handy multi-tool for the many different tasks involved with electronics.  I was thinking about getting a Leatherman Squirt: http://www.leatherman.com/product/Squirt_ES4 for its needlenose-ish pliers and various wire strippers.
While it's handy I think that it could be improved in a few ways.  The wire cutter is nice but it would be great to have it flush.  Also the screw driver could use a long and skinny shaft to reach into screw recesses, maybe with a flippable phillips and flat tip.  Also a 30 AWG stripper for wire wrap wire would be nice.
Offline ivan747
Re: Multi-Tool for DIY electronics
« Reply #1 on: July 24, 2011, 12:45:24 pm »
I have been thinking about the Leatherman Juice S2. I think is handyer because it has the philips screwdriver. After all, I always end up stripping wires with pliers.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: July 24, 2011, 09:48:43 pm »
i have leatherman wave like clone. and i think i'm not a fan of it indoor. but it will be handy when outdoor where you have nothing or hard to bring all the gadgetries around.
i also have smaller leatherman version whose purpose is only idling on my desk.
for indoor i prefer more dedicated tools...
http://76.my/Malaysia/multi-wire-terminal-crimper-cutter-stripper-pliers-88996-1009-16-aaronngu77@1.jpg
http://76.my/Malaysia/38-1-high-rigidity-ultra-precision-alloy-screwdriver-set-mobile-pho-1004-26-gmh81@11.jpg
http://76.my/Malaysia/wire-cutter-stripper-pliers-tool-150mm-wn218n-1003-24-aaronngu77@6.jpg
i will get the flat cutter like dave's when i come across the hardware shop.
« Last Edit: July 24, 2011, 09:55:48 pm by Mechatrommer »
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #3 on: July 24, 2011, 10:39:45 pm »
Can I have the last one ( from the links)  as gift ?   :D
HLA-27b
  • Guest
« Reply #4 on: July 25, 2011, 01:02:26 am »
My favorite is Swisstool Spirit Plus
Swiss guys definitely know how to do these things.
I loaded mine with thin neck long bits and also torx t25 and t30's.
It's amazing how handy it is. If I ever loose it I'll have to buy a new one the next day.
Uncle Vernon
  • Guest
« Reply #5 on: July 25, 2011, 01:02:45 am »
looks like a pocket knife. smells a little of spam.
A tool that does many things and none of them well won't be a priority in any good tool kit.
HLA-27b
  • Guest
« Reply #6 on: July 25, 2011, 01:13:22 am »
A good toolkit with all the best tools stays at home and is not around when it is needed. I much prefer a so so tool that is at hand when it is needed. Is this spam btw? I can remove the picture...
Uncle Vernon
  • Guest
« Reply #7 on: July 25, 2011, 01:21:23 am »
I just cant come at half assed tools at any time, I should invest in a designer wheelbarrow to cart the toolboxes about when on site.
The spam reference wasn't pointed at you, apologies I should have made that clear.
When post number one from a post count of one links to an apparent bargain on a vendor site, my spam detector begins to show movement.   Cheers
Offline lowimpedance
  • Watts in an ohm?
« Reply #8 on: July 25, 2011, 01:49:50 am »
Got a cheapy leatherman style clone from Aldi's just for the car glovebox only.
never used it for anything serious.
oh wait I did use the blade to cut the tag of the wifes new pair of shoes recently  :P
Offline Vertigo
« Reply #9 on: July 25, 2011, 05:44:43 am »
i have a leatherman charge AL, which is the same as a 'wave' model,
except that it has more high grade blade steel on the knife blades (154cm vs 420hc in the wave)
its a great tool, but due to it being rather heavy it is not very likely to be on your person at all times.
anyways i would like to point out that the wave and charge come with a bit driver that takes
leathermans proprietary flat bits, but you can get this same capability in a bit holder that
can be attached to the phillips head screwdriver in the juice models.
personally i have the leatherman on my desk, but for carrying around i much prefer the victorinox swiss army knives.
i like the form factor much better for carrying, and the scissors are much better then on leathermans. (though the scissors in the juice
are significantly larger) i use the scissors all the time to cut leads of trough hole components and strip wire and things like that.
Offline nukie
« Reply #10 on: July 25, 2011, 06:23:55 am »
Fine, if doing once off job but it's very annoying to operate. I find them very hard to grip. I have many Leatherman, they are very handy especially when it comes to onsite servicing but it's not a tool that can replace everything. I would usually resort to a proper tool. Nowadays, I use them to prune big three trunks, the saw is superb.
« Reply #11 on: July 25, 2011, 08:31:33 am »
Sorry if it looks like spam, figured I'd start a discussion I'm interested in with my first post.  I hope it helps that I was pointing out that that tool is inadequate in certain areas.
Of course a multi tool not at good at doing a certain job than dedicated tools.  That isn't the point of it o_O.
Uncle Vernon
  • Guest
« Reply #12 on: July 25, 2011, 08:54:09 am »
Not a problem, sure it wasn't intentional.  Welcome to the forum. looks like your not alone in a love of pocket tools. Enjoy.
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #13 on: July 25, 2011, 08:59:11 am »
I believe that those  " tools " if you can call them as " tools ", they are good so to handle one small emergency,
when your precious tool box is miles away, and you are lost in to a camping spot, trying to fix the plug of the antenna for the portable TV.
There is no Multi-Tool for DIY electronics, and the title of this topic it is a bit elusive.  :)
Follow this topic for more info, if you do like such compact mini tools.
https://www.eevblog.com/forum/index.php?topic=1105.0
Uncle Vernon
  • Guest
« Reply #14 on: July 25, 2011, 09:09:58 am »
Why would anyone want a portable TV while camping?  :o  The things people do.  :-\
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #15 on: July 25, 2011, 09:16:57 am »
It looks that you do not have friends that they are fanatic's about watching football on TV .. LOL
Uncle Vernon
  • Guest
« Reply #16 on: July 25, 2011, 09:31:22 am »
Actually I have a life!  ;) And a smartphone!  to cater for such urgent updates.  ;D   The only reason I can think of for someone to lug an actual TV into the bush, would be if they had no intention of bringing it back. And I cannot condone that sort of littering.  ???
  • Country: my
« Reply #17 on: July 25, 2011, 10:37:00 am »
And a smartphone!
is it sattelite phone? if not, you'll only see "black and white ants" scattering around your monitor randomly.
Uncle Vernon
  • Guest
« Reply #18 on: July 25, 2011, 10:57:02 am »
And a smartphone!
No ants on my monitor, What are you talking about? You can try and stick some ants on if your brave.  :o
Re: reception it's ok I'm not on Voda.
« Last Edit: July 25, 2011, 11:00:13 am by Uncle Vernon »
  • Country: my
« Reply #19 on: July 25, 2011, 01:57:59 pm »
this is what happen with no satellite access in the bush
Uncle Vernon
  • Guest
« Reply #20 on: July 25, 2011, 09:57:00 pm »
You must be with Vodafone!  ::)
Offline ivan747
« Reply #21 on: July 26, 2011, 01:10:02 am »
Ahh, I wonder how much time did I waste looking at that thing on the screen when the cable service was broken, oh memories  ::).
Offline PedroDiogo
  • Country: pt
  • EE Student
« Reply #22 on: July 26, 2011, 09:36:00 pm »
As anyone tried tools made by Swiss Tech before? I found them on a quick search through amazon and their tools seem pretty good and at a fairly cheap price.
I think I will buy this one, because many times when I'm at college I need to strip wires and never happen to have nothing to strip them with handy!
http://www.swisstechtools.com/productdetail.aspx?PID=Jqqivc4el7cA
Offline Vertigo
« Reply #23 on: July 28, 2011, 11:19:29 am »
i don't own any myself, but those things have a good reputation in that they work well.
only downside is that those are a bit on the heavy side vs the number of tools you get.
(when you carry tons of crap like i do it becomes an issue)
but if that doesn't put you off, i'd say go for it.
Offline img
« Reply #24 on: July 28, 2011, 12:48:01 pm »
How's the quality of the bit/handle set?
