Author Topic: What happens to EMWaves when they transition from RF to IR? Why do wire/glass...  (Read 669 times)
Offline BeaminTopic starter
  • If you think my Boobs are big you should see my ba
...conduct the same waves but very differently?? Why can wires transmit RF but a certain point you have to go to glass? Why can glass transmit UV but not RF , X or Gamma rays? Is there some magic cross over frequencies or is it gradual? I also never figured out why IR is also heat, UV catastrophe aside.
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
Offline coppercone2
the dielectric permittivity changes in regard to frequency. I think you need to approach all problems of this nature from the permittivity. Does the atomic mechanism of permittivity change with frequency with a severely nonlinear mechanism is what you are asking ?
Wires are misleading because of CISPR that engineers are familiar with, you need to think in terms of impedance. 30Mhz is a good cutoff point for wire useful conventional transmission but the signal propagates at a impedance we do not like for some distance more, look into power line communications and frequency relationships to see the 'true behavior' of wires that you are familiar with (romex, etc) in regards to higher frequency so you understand how the properties degenerate to a less useful and more chaotic system as frequency increases.
A simple but dangerous thing you can do is to make a high impedance probe that connects an outlet to a spectrum analyzer, a series of CR filters, fuse and a snubber will work, isolation if you can figure it out will help, and setting up the equipment so that you do not touch it when the plug is connected to the mains (do not fiddle with the spectrum analyzer after the wire is plugged into the wall, disconnect it, reconfigure the display, then reconnect, and count your lucky stars that the SA did not break from some nasty line abberation). I would say do not do this unless you don't care too much about the equipment. It is a lot of work for a glimpse into mains... and possibly quite dangerous.. the scope FFT is much more safe here if you are competent with a oscillscope.
As for spacial propagation through dielectric matter this investigation starts to be interesting in the microwave range, you need paraffin blocks and directional antennas (horns are classical) to start to see weird things like prisms made of candle wax effecting microwave energy.
You must think in terms of dielectric and conductor and remember that normal wiring is a complete mess to RF and will be chaotic.
Look into classic experiments around the late 1890's to see how people deal with microwaves at first before we have established waveguides etc.
Also look at a catalog of microwave antennas from a distributor that goes up to very high frequencies to see the change of equipment, it seems fairly linear for most things.. the horns get smaller
this was alot more obvious 50 years ago but now there are lots of pin diodes/solid state switching networks and weird antennas that make this very confusing (i.e. ceramic chip antenna), the things that likely made those designers think 'oh shit thats weird and cool' are the norm and majority now.. so its mindboggling.
« Last Edit: March 10, 2021, 05:00:30 am by coppercone2 »
Online T3sl4co1l
    • Seven Transistor Labs
At optical frequencies, metals have a very high, imaginary index of refraction.
At low frequencies (say, < THz), we express that as resistivity.  Resistivity includes a length dimension (e.g., ohm-meters), meaning it depends on scale.  So, long waves encounter a lot of material, and therefore a low resistance, so are easily reflected by metal surfaces -- hence waveguides (TE or TM modes) and transmission lines (TEM00 mode).  But short waves encounter much less, much more often -- so the attenuation is much higher.
Essentially, the attenuation of a waveguide or transmission line, scales proportionally to width.  At radio frequencies, we use coax and other cables, of various human-scale dimensions.  Something like RG-8 is good up to some tens of GHz.
Transmission lines stop being useful, when higher order waveguide modes take over.  You lose the valuable assumptions (flat frequency response, impedance, low dispersion) and so either thinner cross sections need to be used (the lowest waveguide mode is inversely proportional to width), or proper waveguides must be used (which have significant dispersion even in the intended operating band, making them a challenge for some applications.
Transmission line or waveguide can only be made so small, until, well for one it's just so hard to handle (and must be made to such exacting tolerances, connectors especially), but also the number of waves interacting with it per unit length goes up with frequency.  Basically, the losses, the attenuation per length, goes up and up and up, and pretty quickly it becomes futile -- useless over any real distance.
Waveguide has higher efficiency (lower loss per length), so is useful to higher frequencies than TLs, but the same problem once again applies.
At some point, we stop using wave physics, and geometric optics takes over.  We note that a waveguide is simply a shell of very high index of refraction, with a low index inside of it.  The reflection off that high index, is where the low loss comes from.  Where does the remainder go?  It is absorbed.  At low frequencies, we use skin effect; at high frequencies, the skin is so thin (fractional um) that we really don't care anymore (it's only relevant for metal films, perhaps*) and can consider its index of refraction instead.
*Which, if you've ever held a CD up to a bright light, you'll have noticed they transmit blue light, of all things.  This is probably partly due to thickness (interference blocking red light from passing?) but also partly due to plasma frequency or something like that (metals stop being metallic at high enough frequencies).
The index of refraction is given by the dielectric permittivity and magnetic permeability of a material.  Well, for something like copper, permeability is 1, that's easy.  What's permittivity?  Well, in the same way that a resistance becomes an inductance when multiplied by the imaginary constant j = sqrt(-1), a capacitance becomes a resistance when multiplied by j.  So we can encompass both dielectric permittivity, and resistivity, as a complex-valued permittivity.  So, when I said earlier that metals have a high, imaginary index of refraction, this is what I mean -- it's a roundabout way of saying, the resistivity is much lower than that of free space, and indeed dominant over the permittivity of free space as well.
And it is indeed an index of refraction; if we look at metal films, the thickness required for attenuating certain frequencies, is very thin indeed (10s, 100s nm?).  We might wonder about total internal reflection, but the loss means it's not going very far, so, nevermind that.
Oh yes, loss -- an imaginary index, means it attenuates as it goes -- the wave vectors point in on themselves and decay exponentially; whereas for the real case, they continue spiraling around as normal.  It's the opposite of how we use complex numbers for AC signals, with real values corresponding to growth or decay, and complex values corresponding to oscillation (i.e., the value of exp(a + jb)).  Simply put, when the index appears in wave equations, it happens to be paired with a j, swapping the real and imaginary components around to give the expected mathematical correspondence.
And, as it happens, magnetic materials aren't much better; YIG is good in the low GHz, but I don't think is useful much higher?  (I see a few articles with YIG and THz keywords, which look to be pretty crazy stuff well above my pay grade..!)  Not sure what else, if anything, extends up there.
So we use dielectric waveguides, to go higher.  We can use these just fine at ~GHz frequencies too, they're just rather bulky -- the waves aren't strongly contained, the field is nonzero outside of the main body and tends to leak into anything nearby.  We need to reserve a lot of space to prevent that, or add additional layers (with thickness on the order of 1/4 wavelength each!).  Or use a properly shielded waveguide, which, well, just wrap the thing with metal right, can put anything right up outside one of those -- hence standard metallic waveguide, eh?
But at optical frequencies, not only can we afford extra shielding, in terms of available space -- we are obliged to use it!
So, we make optical fiber for instance, with a high index n in the core, surrounded by lower n, surrounded by a jacket, or additional layers, or air.  This exhibits total internal reflection (just how, underwater, the water surface looks nearly perfectly shiny at glancing angles), and the material losses can be amazingly low.
So, all this is a big part of why high frequencies "don't like to stay inside wires".  There's some additional weirdness as well, when it comes to metals, in the THz range.  Metals work, because electrons are free to move within them; at some frequency, this assumption no longer holds.
Imagine incident waves, with a frequency on the order of the effective mass of electrons in the metal.  This... is a bit of an abuse of units, you can't compare mass and frequency after all.  Well, the electrons have some energy level (thermal or Fermi) which gives them a velocity and equivalent frequency, the plasma frequency.  (I'm really winging it by this point, by the way; I know very little about the underlying statistical mechanics in this regime.)
Also something about Debye length, which has to do with the shielding effect of electrons in the metal.  That is, if we apply a (static) electric field, electrons will be drawn or repelled by that field, at the surface; but how thick is that "surface" really?  The answer is, this length.  The electric field penetrates into the (atomic) surface, on the order of this length.  10s of nm for most metals, I think it is?
Effectively, weird things happen when the classical skin effect depth, is of the same order as the Debye shielding length.  It is no coincidence, that these effects take over, at frequencies where quantum energies are substantial -- the band structure of the metal might be some eV across, so we expect to see something interesting happen for photons on the same order -- i.e. visible to UV light.  Indeed, all metals (as far as I know?) have the effect of looking "pink", like copper does: the only difference is what wavelength is "pink" to them.  Copper happens to have the lowest cutoff (plasma frequency), so looks pink in visible light.  Gold, and to an even lesser extent cesium, looks well, golden, having a somewhat higher cutoff.  Most metals look silvery because the cutoff lands in the UV range (say 5-10eV).  But if your eyes could see into the UV spectrum, you would see exactly the same cutoff for everything else.
The plasma frequency generalizes to any conductor (or gas of charged particles, at least -- including actual plasmas, hence the name).  The lower the carrier density, or interaction rate or something, the lower the frequency -- as it happens, Earth's ionosphere has a cutoff around 30MHz, below which it is reflective (hence the long distance propagation of short- and long-wave radio signals), above which it is transparent (hence VHF+ for space communication and radioastronomy).  The interplanetary medium is also a plasma, with even lower frequency cutoff -- we might expect to get effective shortwave, even very long wave (10s kHz?) radioastronomy at a moon base (there have been proposals to use craters as huge antenna dishes substantially dwarfing the former Arecibo!) -- but not much below that, as the interplanetary medium is filled with plasma from the solar wind, with a cutoff frequency of some... kHz? 100s Hz?  Not sure, somewhere around there.
Which means, down in the ELF, we well and truly are, by ourselves, all alone in the dark -- well, in the white noise of solar and planetary EM activity at least.  We will most definitely never see communications from extraplanetary sources in the <kHz.
Seven Transistor Labs, LLC
The following users thanked this post: Wolfram, Cubdriver, Mazo
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
As an 'aside', this reminded me of my days in the Security industry...
Most people would have heard of 'PIR's. (Passive Infrared Sensors). The likes of which are used in typical domestic/commercial situations
to detect 'people' movement in a Room etc.  They rely on the natural Infrared being emitted from the likes of a Person, that is received
by the sensor, as opposed to 'Active' systems which 'emit' Infrared (etc!), and look at what is 'bounced' back...
They soon found, that a sheet of GLASS will block the passive Infrared, returned to the 'Sensor' from say a 'Person'. That's why it is very
foolish to have a Sensor on the other side of a window, or glass pane, as they will FAIL to properly detect movement on the other side!  8)
A warning though...  Some Bright Sparks have tried to utilize this phenomenon by carrying a sheet of glass in front of themselves, or more
particularly in the direction of the PIR sensors.  OOPS... Fail...  The detectors don't see YOU as such, but because they are comparing what
they 'see', to the IR temp of the general background, (which changes throughout the day/night as things heat/cool down), it sees the diff
between the edge of the glass, to the background! as you move. Keeping very still works, but defeats your purpose!!   :phew:
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
