Author Topic: 840Uf 12 V closes value  (Read 568 times)
Offline jerryvbTopic starter
« on: June 24, 2020, 11:07:29 pm »
Hi I am  fixing  Tektronix scope 2215  at thepower supply  the capacitor C972,C975 C985 are  840Uf 12V , that need to replace. I  can't find the value much to this 3 caps.
What  do you think the best replacement value for this 3 caps ???
emai me at jerryvcb@gmail.com
Offline amyk
Re: 840Uf 12 V closes value
« Reply #1 on: June 25, 2020, 12:16:27 am »
820/16 is the closest standard value.
The following users thanked this post: jerryvb
Online floobydust
« Reply #2 on: June 25, 2020, 01:51:26 am »
I find modern electrolytic caps caps are low in value, close to their rated -20%, whereas the old Spragues were +100%/-10%.
I use United Chemi-Con EKYB250ELL102MJ20S 1,000uF 25V in Tek scopes.
I recommend to upsize to 1,000uF as the 2235A did. I believe your power supply is similar, here is spreadsheet with those cap details and sizes, taken from thread: https://www.badcaps.net/forum/showthread.php?t=71125
