Author Topic: Whats the heaviest oscilloscope probe you know of?  (Read 3808 times)
Offline ConKbotTopic starter
« on: July 10, 2014, 08:04:56 pm »
http://www.home.agilent.com/agilent/redirector.jspx?action=ref&cname=AGILENT_EDITORIAL&ckey=1210550&lc=eng&cc=US&nfr=-34025.536883024.00
on page 14:
Pack the probe in the original shipping containers. Original materials are
available through any Agilent office. Or, use the following guidelines:
• Wrap the probe in antistatic plastic to reduce the possibility of damage
caused by electrostatic discharge.
For probes weighing less than 54 kg (120 lb), use a double-walled, corrugated
cardboard carton of 159 kg (350 lb) test strength.
• The carton must be large enough to allow approximately 7 cm (3 inches) on
all sides of the probe for packing material, and strong enough to accommodate
the weight of the probe.
• Surround the equipment with approximately 7 cm (3 inches) of packing material,
to protect the probe and prevent it from moving in the carton. If packing
foam is not available, the best alternative is S.D-240 Air Cap™ from
Sealed Air Corporation (Commerce, California 90001). Air Cap looks like a
plastic sheet filled with air bubbles. Use the pink (antistatic) Air Cap™ to
reduce static electricity. Wrapping the probe several times in this material
will protect the probe and prevent it from moving in the carton.
I want to see the probes weighing over 120 lbs  8)
Offline electronics man
Re: Whats the heaviest oscilloscope probe you know of?
« Reply #1 on: July 10, 2014, 09:11:26 pm »
do u mean heavy as in mass or as in "thats heavy man"
follow me on twitter @get_your_byte
Offline sfiber
  • Country: tr
« Reply #2 on: July 10, 2014, 09:16:39 pm »
he means about mass
Offline Tinkerer
« Reply #3 on: July 10, 2014, 11:06:51 pm »
What would you even use those for? Directly probing a 1MW generator or something?
Offline rob77
  • Country: sk
« Reply #4 on: July 11, 2014, 01:15:52 am »
probably a small anvil and a hammer is bundled with the probe  :-DD
