Author Topic: mini sd card. Do you have any devices that use these.  (Read 2944 times)
Offline Ed.KloonkTopic starter
  • Cat video aficionado
« on: December 08, 2012, 09:29:21 pm »
Mini SD card. Not Mirco or plain old full-size SD cards.
I bought an adapter kit that takes micro sd cards and converts them to the two bigger sizes.
There are two adapters in the kit. Once does micro SD to Full size SD. The other one takes a micro sd and coverts it into a mini sd card. It is this adapter I have yet to find a use for. All my gear is either micro sd or full size SD. No mini sd slots anywhere.
The question I have is this: Have you any devices that accept mini sd cards? If so, what are they?
iratus parum formica
Offline NiHaoMike
    • Facebook Page
Re: mini sd card. Do you have any devices that use these.
« Reply #1 on: December 08, 2012, 09:33:42 pm »
If nothing else, solder some wires to the adapter and use it as a socket for a microcontroller project!
Offline bitwelder
« Reply #2 on: December 08, 2012, 09:46:27 pm »
I still have a working (but not currently in use) Nokia N80 that takes miniSD cards.
« Reply #3 on: December 08, 2012, 09:49:59 pm »
That is a good idea.
« Reply #4 on: December 08, 2012, 09:50:48 pm »
Ah. Ok. It's the only device I've ever seen that takes the mini SD.
Offline G7PSK
  • It is hot until proved not.
« Reply #5 on: December 08, 2012, 10:11:26 pm »
I have a mini SD  to compact flash card converter.
Offline T4P
  • Country: sg
    • T4P
« Reply #6 on: December 08, 2012, 10:41:49 pm »
The last time i used or seen a MiniSD was a Nokia 6288 in early 2007  ^-^
Offline peter.mitchell
« Reply #7 on: December 09, 2012, 05:17:13 am »
i have a couple of old Chinese digital cameras that use them.
« Reply #8 on: December 09, 2012, 08:39:28 am »
The slots at not built into anything new in the last several years. Safe to assume they are dead then huh?
Poor Mini SD card format. We hardly knew ya.  :'(
Offline westfw
« Reply #9 on: December 12, 2012, 07:04:15 am »
I found a bunch of cheap mini-SD sockets on eBay.  Easy to solder/etc, and you can use micro-SD cards with them via an adapter.  (micro-SD cards are just TOO tiny.)
(This is a mini-SD adapter for The Mattel "JuiceBox" multimedia player.  At one time, these small ARM/linux-based toys were being liquidated for about $10 each.  With no modifications, they'll play some pictures and MP3 files from an SD card.  With "some" modifications, they can be a tiny linux system.)
« Last Edit: December 12, 2012, 07:07:09 am by westfw »
« Reply #10 on: December 12, 2012, 07:32:55 am »
 8)
