Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Can you name this top insert side screw PCB terminal found on Sonoff panels?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Can you name this top insert side screw PCB terminal found on Sonoff panels? (Read 450 times)
tomayr
Newbie
Country:
on:
October 03, 2023, 12:09:52 pm »
They are found in Sonoff NSpanel boxes on the relay board. PCB mount. Side screw.
I can't seem to find it for the life of me.
Logged
spostma
Regular Contributor
Country:
Re: Can you name this top insert side screw PCB terminal found on Sonoff panels?
Reply #1 on:
October 03, 2023, 08:17:12 pm »
not exactly the one you look for, but it looks like a single contact of a vertical entry terminal block like
https://www.metz-connect.com/externalfiles/311631/863662.PDF
By the way, this horizontal single contact block with 3.1mm hole, M3 screw and double mouting pin can be used for many mechanical mounting solutions:
https://www.metz-connect.com/home/products/u-contact/pc-board-terminal-blocks/screw-type-terminal-blocks.7f.en.html?id=360410
Logged
ZigmundRat
Regular Contributor
Country:
Reply #2 on:
October 03, 2023, 08:27:05 pm »
Not quite right, but fairly close:
https://lugsdirect.com/IHI_HIGH_CURRENT_PCB-TERMINALS-_SELECTION_CHART2.htm
Or maybe:
Last Edit: October 03, 2023, 08:42:50 pm by ZigmundRat
Logged
tomayr
Newbie
Country:
Reply #3 on:
October 03, 2023, 09:57:06 pm »
Thank you for the responses so far.
It's odd that it wouldn't be a more readily available item. I scoured all of Metz's brochures and website as they seemed to be the most likely to manufacturer such a piece. I can't imagine its unique to Sonoff?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
