Hi All,
I have an Nikon SMZ660, with the C-W10xB/22 eyepieces and G-AL 0.7x objective on a boom, soldering under it with the cheap MIC-209 LED ring lamp works well for me.
I have a camera and adapter that goes in one of the eyepiece cavities, I want to use it for board inspection, it works but I'm getting a ton of reflection from the pads, pins and solder, anything silver goes white with overexposure, I have tried changing the camera settings, lamp brightness and using printer paper as a makeshift diffuser (the diffuser helped a bit) has anyone had this issue and solved it?
Thanks.
Richard
