Author Topic: mental images  (Read 1589 times)
Offline DeathwishTopic starter
  • Country: wales
mental images
« on: December 16, 2015, 05:26:49 pm »
How many of you see a series of 4 numbers or so and your brain starts trying to associate it with some piece of kit ?.
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Online TimFox
Re: mental images
« Reply #1 on: December 16, 2015, 10:16:23 pm »
I always compare 4-digit lottery numbers to the American industrial/military vacuum tube numbers that started at 5500.
Online T3sl4co1l
    • Seven Transistor Labs
Re: mental images
« Reply #2 on: December 17, 2015, 09:02:31 pm »
I saw "1723" the other day and thought it awfully familiar.  Though the only thing that came to mind was, Motorola regulator IC?
I spot "11:38" seemingly more often than chance (unsure whether it's subconscious, confirmation bias or what).  Odd as I've not seen the movie, and am only passingly familiar with the lore.
Numerology is much more fun when you have random part numbers floating around in your head. :)
Seven Transistor Labs, LLC
Offline German_EE
Re: mental images
« Reply #3 on: December 18, 2015, 08:23:40 pm »
555 (quite common on German car plates) means the timer IC
723 is the voltage regulator
741 (I'm old) is now a rather poor opamp
7474 is a dual FF
and of course 42 is the meaning of life, the universe and everything
Warren Buffett
