I lost the link some time ago, but I once saw an analysis of A/C condensate. Now, to be fair, the contents will depend on your location, but this is NASTY stuff! It is full of bacteria, viruses, fungi, chemicals known both inside and OUTSIDE! of California to cause cancer, pollen, dust and other general nastiness. Calling this stuff water is like calling smog "air".
The reverse osmosis mention was interesting. Did they just bolt the unconnected RO membrane in the case somewhere? Even a very efficient RO membrane has something like a 3:1 reject to filtered water ratio and requires relatively high pressures. Are they condensing 3x-5x the resulting filtered water? Where is the effluent drain?
