I somewhat remember, a similar thing, to the theme of this thread (challenging master/slave), something around 25 to 35+ years ago. It was an attempt to make things much more inclusive (around male/female terms), a sort of women/female-movement.
E.g. Renaming of Firemen, Policeman, Postman, Binman, etc. As well as many other things, to 'balance out', the mix of sexes (male/female), across jobs, and make it much fairer, for women.
E.g.
https://en.wikipedia.org/wiki/Convention_on_the_Elimination_of_All_Forms_of_Discrimination_Against_Womenhttps://en.wikipedia.org/wiki/Gender_equalitySo, around 1980 I guess, so approximately 40 years ago.
What you want/need here, is equal opportunity, to do the different jobs, regardless of disability, age, male/female, weight, height, background, race, religion, etc etc. With (hopefully) obvious exceptions.
But what you don't want/need, is to force each job type, to have a mixture/balance, EXACTLY the same level as in the general population. Because if you force it, it can mean that unsuitable people are given the job, who are not really interested in it. Which can be damaging for that job function.
I.e. If you are suited to be an Electronics Engineer, then you can be, even if you are different to the normal profile of an Electronics Engineer.
But, forcing, e.g. 50% of them to be female, could mean that you end of with people, who are not interested in engineering, and it could damage the quality of the items, or lead to sky high salaries, in order to attract, the few, genuine engineers, from that category.
I.e. Equal opportunity, not forced percentages, imposed on employees.
Get the job(s), because of your merits for doing the job, not because you tick the population mix percentage tick boxes.
