I work as an aircraft mechanic to do some functional checks, I am in need of a sign wave generator that is capable of putting out at least 3VPP and a wide range from 0hz to 5000HZ. The last time we ended up borrowing an older box with just knobs and no display, and using a fluke 179 to watch the frequency and voltage to dial them in. I see some more expensive ones on amazon but any recommendation on a good unit under the 500$USD range that would get this done and be good quality? Something with a display that is capable of being sent in and Calibrated?
Something like this is what I was hoping for.
OWON Waveform Generator,30MHz Bandwidth, 125MSa/s Sampling Rate, 14 bits Vertical Resolution, 8K Waveform Length,5 Basic Waveforms, <Cheap but claims 4VPP but would rather not waste money.
Siglent Technologies SDG1032X Arbitrary Waveform - Function Generator <Middle of the road price.
More information on the test I am asking about.
adjust the Sine-wave Generator (2V / 0-1000Hz) to give the frequencies at between 1.8 Vpp and 2.2 Vpp. Read the NR indications on the triple indicator.
____________________________________________________________________________________________________________
Connect the sine-wave generator (2Vpp / 0-5000Hz) to the connector N1 of the N1 speed sensor as follows:
NOTE
A frequency of 4100 Hz simulates N1 > 50 %.
A frequency of 3900 Hz simulates N1 < 50 %.
Any Advise on something that would complete this and not be overly expensive but also be of a good quality would be awesome.
Thanks,
EDIT: Or if this is the wrong section to ask this question direct me there.
