Sure.
Inputs are 1,3,5,9,11,13. All are tied to the bus on the side, which I'm feeding with the FG. Red clip is from the FG, Black clip is the "gnd" from the FG.
Red wire heads off to my PSU positive with +5V rail. Black wire (where the black clip is) also heads off to the PSU gnd (negative). My scope probe is clipped to that wire out of frame. Obviously pin 7 is gnd, pin 14 is +5V (Vcc).
Just testing the output pins with my scope. Once I got it all hooked up, the chip was pulling 20mA of current at 5V from my PSU.
I don't THINK there's any issue with this, but I'm just a beginner, so I could be completely off base. Mind you, this is the chip that appeared to be bad from all other testing, and in circuit.
