Author Topic: LIVE: Launching astronauts from US soil to ISS for first time in last 9 years  (Read 5511 times)
Offline Mr. Scram
  • Display aficionado
Found today that SpaceX writes their code in C++, their screens in JavaScript, the OS is Linux, and the platform is PowerPC. They do not use rad-hard components but instead shield at the modular level.
They also use ridiculous amounts of redundancy. Almost every CPU is tripled and the set uses majority voting. There are many, many CPUs aboard for all kinds of subsystems.
Offline IDEngineer
That's very common. Even the Shuttle had such redundancy. IIRC, it had five computers, three of which were "live" at any one time, with one auto-backup and I can't remember when the fifth came into play. On the original launch in 1980(?) one shut down and a backup kicked in. Then a SECOND one shut down. I remember John Young saying his knees got a little weak at that point. But it all turned out fine... it wasn't CPU's that cost us two Shuttles and two groups of astronauts.
Offline 0culus
IIRC the final computer ran software independently developed from the primary ones.
https://history.nasa.gov/computers/Ch4-3.html
Offline IDEngineer
That's what I thought I remembered, but wasn't sure so I didn't want to say so.
I'd be tempted to specify things at the MODULAR level and have separately developed hardware too, but rad-hard stuff isn't exactly commonplace. SpaceX's approach of hardening the enclosure is the better solution IMO because it affords such flexibility.
Offline dr.diesel
During the Starlink launch last night the host mentioned the SpaceX Software Team will be hosing a Q&A on Reddit in the next couple weeks.  Might be a great opportunity for further info on OS/Touchscreens etc.
Offline Sal Ammoniac
It's likely because Mr Musk is on the scene, and has forced giant iPad-esque touch panels into Teslas... WHY? Who knows! Because it's ... "futuristic" and looks "kewl"
Tesla owner here. I find the large touchscreen panel to be quite easy to use and it gives me much more information while driving than any dashboard on previous vehicles I've driven. It's never crashed or frozen on me even under extreme conditions (temperatures <0C and >45C).
"That's not even wrong" -- Wolfgang Pauli
Offline rrinker
 Notice also the Crew Dragon has a stick, and there are also buttons for certain functions on the arm rest, where they would be relatively easy to hit while under high G loads. And also notice that the right-hand seat has the buttons on the left side, and the left seat has the buttons on the right armrest. So either person can access the buttons on the other person's seat. This is most definitely not something that was rushed through, the details have been well thought out.
Offline Mr. Scram
Those were the main computers, not all the subsystems. There are crazy amounts of powerful processors in SpaceX hardware. SpaceX also uses commercial grade computer hardware and trusts the redundancy.
Offline Mr. Scram
Last time I didn't have time to go into detail, but it's pretty interesting. Below is a quote without any sources, but it's consistent with what we've heard elsewhere. It's essentially COTS hardware made redundant to a somewhat ridiculous degree. Rad hardening isn't wholly necessary for short orbital hops.
SpaceX uses an Actor-Judge system to provide triple redundancy to its rockets and spacecraft. The Falcon 9 has 3 dual core x86 processors running an instance of linux on each core. The flight software is written in C/C++ and runs in the x86 environment. For each calculation/decision, the "flight string" compares the results from both cores. If there is a inconsistency, the string is bad and doesn't send any commands. If both cores return the same response, the string sends the command to the various microcontrollers on the rocket that control things like the engines and grid fins.
The microcontrollers, running on PowerPC processors, received three commands from the three flight strings. They act as a judge to choose the correct course of actions. If all three strings are in agreement the microcontroller executes the command, but if 1 of the 3 is bad, it will go with the strings that have previously been correct. The Falcon 9 can successfully complete its mission with a single flight string.
The triple redundancy gives the system radiation tolerance without the need for expensive rad hardened components. SpaceX tests all flight software on what can be called a table rocket. They lay out all the computers and flight controllers on the Falcon 9 on a table and connect them like they would be on the actual rocket. They then run a complete simulated flight on the components, monitoring performance and potential failures.
SpaceX engineers perform what they call "Cutting the strings" where they randomly shut off a flight computer mid simulation, to see how it responds.
Dragon uses a similar triple redundant system for its flight computers.
Apparently they use LabView for the ground based stuff:
The Flight Software team is about 35 people. We write all the code for Falcon 9, Grasshopper, and Dragon applications; and do the core platform work, also on those vehicles; we also write simulation software; test the flight code; write the communications and analysis software, deployed in our ground stations. We also work in Mission Control to support active missions.
The Ground Software team is about 9 people. We primarily code in LabVIEW. We develop the GUIs used in Mission and Launch control, for engineers and operators to monitor vehicle telemetry and command the rocket, spacecraft, and pad support equipment. We are pushing high bandwidth data around a highly distributed system and implementing complex user interfaces with strict requirements to ensure operators can control and evaluate spacecraft in a timely manner.
https://space.stackexchange.com/questions/9243/what-computer-and-software-is-used-by-the-falcon-9
Offline rdl
They use Chromium and JavaScript for the Dragon 2 flight interface.
Wow, so Dragon 2 displays are basically using a web browser.
(if that quote is correct)
Offline tom66
I wonder how much validation you'd have to go through to prove that Chromium is stable when running a JS web app for crucial flight information displays.
I've managed to crash it pretty easily doing fairly normal things.
Offline dr.diesel
If optimized and debugged for that particular set of functions, reliability might not be an issue.
Offline dr.diesel
Offline StillTrying
  • Country: Broken Britain
How come we heard a splash the moment it touched the water when the TV camera is 3 miles away. :-//
https://www.cnet.com/news/spacex-splashdown-smoothly-delivers-nasa-astronauts-back-to-earth
« Last Edit: August 02, 2020, 07:02:06 pm by StillTrying »
Offline paulca
Em... I checked the SpaceX live stream and on it too is the splash at touch down.  WTF?
Offline SilverSolder
Fake news...   should be used to it by now!
Offline Monkeh
Because that wasn't a splash, it was the room mic being unmuted so you could hear applause.
Offline paulca
I think it was played on the control room PA by someone.
Offline StillTrying
"Because that wasn't a splash, it was the room mic being unmuted so you could hear applause."
I've re-wound skynews and watched it 6 times, it definitely sounds like a splash to me! :-//
There's a boom 30 sec after the splash, = ~4.8 miles. 5.8 miles. :-//
The 50 years old recovery method is definitely not as neat as a shuttle landing. :)
« Last Edit: August 02, 2020, 08:55:46 pm by StillTrying »
Offline chris_leyson
  • Country: wales
Nothing wrong with touchscreens if you build them to meet or exceed avionics and space qualifications. I think wraper summed it up with the shuttle flight deck photo
Also do you think this is more practical than 3 touchscreens and a few buttons? If it does the job well, put something that takes minimum space and weight which are quite limited resources in space capsule.
Also nothing wrong with a web browser HMI, they work well and if the hardware fails over for whatever reason you've still got a backup Ipad or two. The flight sofware and the Draco thrusters worked flawlessly to autonomously fly the Dragon capsule back to earth and get Doug Hurley and Bob Behnken home safely.
SpaceX have renegotiated their contract with NASA to reuse the DM-2 capsule on the first operational Crew Dragon mission due to launch in September. Whereas other human space flight vendors can't even get their flight software right.
« Last Edit: August 02, 2020, 10:16:05 pm by chris_leyson »
