Look to the RC hobby sector for some much better prices...For instance:http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7573however, I note that these are on backorder at present -- but the price is *much* better than SF.
Do a search for "1s lipo packs". You are looking for a lithium Polymer battery as the one you show is flat and most, if not all, are Lipo, not LiIo packs. On a safety note.... if you can deal with the slightly lower voltage, a LifePO4 pack would be safer as it can deal with being mistreated without the "vent with flames" tantrum that most lipo/liIo packs give you if charged too high or discharged too low.
I use www.PowerStream.comDave.
Ivaneduardo, Send me a PM with your location, pack requirements, eau, connector details, load and charging characteristics. I am the electrical engineer for a battery supplier and can help you out. Strube
I can only find raw cells. The datasheet recommends a "protection circuit module". They are supposed to protect your battery against overvoltage, undervoltage and short circuits. I was searching around for battery protection IC's and I couldn't find many. Am I missing something?
ivaneduardo747, I forwarded your info to our FAE and he will look at what we have in stock that we can offer... We wouldn't be able to to a custom cell for your volume. All of our cells are tested to UN38.3 and will have the accompanied PCM (protection control module / Protection circuit module). We also offer full support for chargers and power supplies if you need that too. Strube
