Author Topic: Lindstrom Cutters  (Read 22411 times)
Offline M. András
  • Country: hu
Re: Lindstrom Cutters
« Reply #25 on: September 02, 2012, 08:00:20 pm »
I hope from the following images you understand why those cutters are almost indestructible: I even do not remember how long I own them (here at my home lab), but except for the accumulated dirt and some minor rust spots, blades are yet perfect.
Please also take a look to the thickness of the blades in the second photo: completely different from the typical 10-20$ cheap cutters.
The following picture shows the size (in mm) of the two models (522N left / 622NA right):
jes what happened to its handle?
what about knipex cutters?
Offline eliocor
    • rhodiatoce
« Reply #26 on: September 02, 2012, 08:33:20 pm »
The handle is soft and made of a substance which does not melt at contact with typical certified electronics cleaners (IPA/...)
Please take care that the cutters in my pictures were used for at least 8-10 years so they are dirty and a bit battered...  ;)
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #27 on: September 02, 2012, 11:51:44 pm »
Excelta seems to make a huge amount of very specialized pliers and look like very high quality also
website http://www.excelta.com/home
Catalog link http://www.excelta.com/asset/file/0000/0045/Catalog.pdf
Offline eliocor
    • rhodiatoce
« Reply #28 on: September 03, 2012, 12:14:48 am »
I think at least half of their catalog is made of rebranded tools: tweezers are for sure made by Ideal-Tek (see my previous posts on EEVblog) and the same is for the cutters.
I recognize them because I own some of them (without any mark because they had some very small flaws: 2 euros apiece was a bonanza!).
From my posts, I think you'll understand I LOVE precision tools!!! Maybe they will cost a fortune, but if correctly used they will last forever.  ;)
Offline ftransform
« Reply #29 on: September 03, 2012, 11:23:20 am »
Can you really notice the difference in cut compared to say cheap swanstrom cutters?
I mean if you are going to pay 300$ for a pair of indestructible cutters why not just buy 5 cheaper cutters for 100$?
Can someone post detailed (microscope?) pictures comparing a cheap cutters wire cut to a 100$ wire cutter cut?
To me this seems similar to audiophoolery but I don't know.. I can practically bite through the wire I am cutting with the cutters...
I noticed that the mis-matched POS chinese no name cutters that came in a cheap tool kit were pretty horrible at cutting wires but I can't imagine it getting better then these full flush swanstrom cutters I bought...
« Last Edit: September 03, 2012, 11:25:46 am by ftransform »
Offline eliocor
    • rhodiatoce
« Reply #30 on: September 03, 2012, 12:06:59 pm »
The reason because I prefer good quality tools is very simple: once I have bought one of them, if correctly used it will continue to work flawlessly for several (even 15-20) years.
Please remember that I use my tools in a professional way (daily usage) and not once or twice a month.
If you prefer to use cheap tools, good for you. In the long term my 50$* will cost less than your cheap 10$ apiece which needs replacement after few months of usage.
I have some good mechanical tools (inherited from my father) which are old like me (50 years) but even for today standards they are flawlessly (their look can be a bit outdated...).
Maybe he spent lots of money, but it was a really good investment.
Sorry, but I'm not able to make the comparison, lacking cheap cutters.
But please take a look to the photos I posted in the tweezer thread: You'll discover the difference from a cheap tweezer (used only few times) and some good ones.
*) I do not know where you got the 100/300$ unit price: I warmly suggest you to change tools distributor! ;) To my knowledge, 40-60$ apiece is the right price for a GOOD general purpose cutter (in 1 quantity)
« Last Edit: September 03, 2012, 12:10:09 pm by eliocor »
Offline ftransform
« Reply #31 on: September 03, 2012, 12:24:17 pm »
I guess I took the hyperbole in this thread too seriously. 40$ seems alot more reasonable.
Btw those tweezers do look nice but I am working on building a vacuum pickup tool.
Offline robrenz
« Reply #32 on: September 03, 2012, 01:14:57 pm »
Now that you mention it, the cutters must be made by Tronex they are identical.
Offline eliocor
    • rhodiatoce
« Reply #33 on: September 03, 2012, 01:43:16 pm »
from their catalog it seems they are not the same...
Offline robrenz
« Reply #34 on: September 03, 2012, 05:06:53 pm »
The Excelta 7000 series is an exact copy of Tronex.  Same handles, same laser etch, stop screws, etc. The last 2 digits of the model numbers are even the same for the same plier. I would be suprised if they are not made by Tronex.
Offline T4P
  • Country: sg
    • T4P
« Reply #35 on: September 03, 2012, 06:13:47 pm »
I didn't build i bought  :P
2 vac pickup tools and a reel holder for only 15USD
Offline nanofrog
« Reply #36 on: September 03, 2012, 09:38:48 pm »
At least some seem to be re-branded Tronex, as the Excelta 7170E I have is an exact match with a Tronex 7070, but though the construction is similar (as you describe), the 7141E doesn't have an exact match with a Tronex part (physical dimensions are different; Medium size is 0.33" for Tronex, 0.44" on the Excelta <jaw length>). Though like you, I suspect it's an ODM product made by Tronex for Excelta the more I compare the two.
Offline ftransform
« Reply #37 on: September 04, 2012, 01:01:21 am »
I wanted to build a compressor one with a foot pedal
Offline Psi
« Reply #38 on: September 04, 2012, 01:21:14 am »
Lindstrom cutters are NZ$100-$300 from RScomponents, depending on model.
eg
http://newzealand.rs-online.com/web/p/electronics-cutters-accessories/2284042/
http://newzealand.rs-online.com/web/p/electronics-cutters-accessories/1205004/
Offline robrenz
« Reply #39 on: September 04, 2012, 01:42:30 am »
Lindstrom and Tronex are both in the $45.00 to $75.00 range depending on model in the US.  We are talking about the carbon steel versions not the tungsten or carbide versions.
Offline T4P
  • Country: sg
    • T4P
« Reply #40 on: September 04, 2012, 02:50:29 am »
i see  :P
Aren't aquarium pumps compressors? Not sure ... But the vac pickup system i'm buying is a compressor ( Of course it's OHL ... )
Offline IanB
« Reply #41 on: September 04, 2012, 03:07:55 am »
Compressors are devices for moving gas from a source at a lower pressure to a destination at a higher pressure. Therefore a compressor is a suction pump on the inlet side and a pressure pump on the outlet side. It's all a question of how you look at it.
