Author Topic: Lindstrom Cutters  (Read 25283 times)
Offline SgtRockTopic starter
Lindstrom Cutters
« on: September 02, 2012, 01:49:51 am »
Greetings EEVBees:
--I want to buy some Lindstrom cutters to cut leads of soldered through hole componets. I would like a smoother and flusher cut.
Exactly what model of Lindstrom should I get?
"We are all born ignorant, but one must work hard to remain stupid."
Benjamin Franklin 1706 - 1790
Best Regards
Clear Ether
Offline robrenz
  • Real Machinist, Wannabe EE
Re: Lindstrom Cutters
« Reply #1 on: September 02, 2012, 02:06:35 am »
I have a pair of these RX series, very nice.  The handles are great, definatley the best style of all the pliers I have.
I also just bought some Tronex cutters that I think may be even better quality than the lindstroms. You should give them a look also.
http://www.tronextools.com/
Cut styles, I assume you would want ultra flush cut
http://www.lindstromtools.com/tools_cutters_how.htm
RX styles,  You will have to pick what style will give you the access you need.
http://www.lindstromtools.com/tools_cutters_rx_assort.htm
Download the RX section of the catalog to get sizes and better pics and dimensions
http://www.lindstromtools.com/download.htm
« Reply #2 on: September 02, 2012, 02:23:39 am »
Dear Robrenz:
--Thanks for the good info. Looks like the Ultra-Flush Cut is the one I want. Now if I can just figure out the model number so I can snipe a pair on Fleabay, skinflint that I am.
"Does not squirrel crack nuts on bough of oak tree."
Lao Fu 1410 1620
Best Regards
Clear Ether
Online Psi
« Reply #3 on: September 02, 2012, 02:43:12 am »
The more flush they are the easier it is to damage them, since the cutting surface is thinner.
eg
/ \  vs |\
Be sure to keep them in a safe place or you will learn the hard way when a friend tries to cut something that's too thick.
(Non-electrical people do not expect cutters to be worth $300 when they pick them up to use).
Don't get me wrong, Lindstrom cutters are awesome and will last almost forever if you cut only correct size wire, but you need to be aware that it only takes one cut of oversize wire to cause damage.
The tip damage here is from when a friend cut something too big.
The smaller damage halfway down i didn't actually know about until i took this picture now.
And these are the semi-flush kind. So the fully flush will be even more easy to damage.
(These are 1 year old.)
« Last Edit: September 02, 2012, 03:26:14 am by Psi »
Offline robrenz
« Reply #4 on: September 02, 2012, 03:20:31 am »
Agreed,
The Tronix actually come with a paper showing the recommended max size in copper at the tip and max size at the back. I like that the Tronix have a adjustable stop screw that controls the closed position instead of the cutting edges having to absorb uncontrolled force. The edges do contact just before the screw but additional force is absorbed by the stop screw.
If you have a microscope and good fine grit stones or diamond files you can recondition those edges yourself. Just takes some time, patience, and correct procedure.
Offline IanB
« Reply #5 on: September 02, 2012, 03:29:37 am »
Alternatively, you can buy a few pairs of these Hakko cutters and be less worried about damage. They really are a very nice cutter: sharp, precise, comfortable to hold.
http://www.scubatools.com/p-433-hakko-side-cut-5.aspx
« Reply #6 on: September 02, 2012, 03:30:01 am »
Dear Psi:
--Thanks for the good advice. I will try to keep from doing anything stupid (like I usually do) with my soon to be good Lindstrom cutters. I like to clean finished boards with Isopropyl Alcohol. If I try to rub the board, the paper towel, or cloth or Q-Tip tends to leave lint snagged on the sharp points of my poorly flush cut component ends. My present system is to first scrub with a toothbrush and Alcohol, (Vodka will work in a pinch, and I am often in a pinch). Then I blot with a dried out baby wipe, and repeat. I hate boards that snag everything, and I hate left over flux.
"Happy for you to desoldering, please."
Wun Hung Lo 1948 -
Best Regards
Clear Ether
Offline IanB
« Reply #7 on: September 02, 2012, 03:36:47 am »
With regard to this particularly, some professional soldering trainers teach that the component leads should be cut to the correct length before soldering. This has two benefits: it prevents a tangle of long leads getting in the way of the iron when soldering a fully populated board, and it avoids the sharp cut edges that result from cutting after soldering.
Offline robrenz
« Reply #8 on: September 02, 2012, 03:37:21 am »
A very light touch scuffing with a fine grit sanding sponge in circular pattern might do the trick on all those picky little burrs.
Offline FenderBender
    • The Solid State Workshop
« Reply #9 on: September 02, 2012, 03:43:55 am »
I saw Home Depot had like a 2 piece Xcelite shear cutters set. $14 for two. http://www.homedepot.com/Xcelite/h_d1/N-644Z5yc1v/R-100163974/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051#.UELVLtYiatk
Not bad if you live near a Home Depot, in my opinion.
« Reply #10 on: September 02, 2012, 03:46:33 am »
Dear IanB:
--Thanks for the tip on the Hakko nippers, I love Hakko. I have 2 936s, one for light and one for heavy, for really heavy I have the Weller Industrial Gun. I notice that Lady Ada (Adafruit Industries) is offering the Hakko nippers, but so far, only on eBay and out of the UK, go figure.
“You can't help respecting anybody who can spell TUESDAY, even if he doesn't spell it right; but spelling isn't everything. There are days when spelling Tuesday simply doesn't count.”
Winnie the Pooh 1925 -
Best Regards
Clear Ether
Offline T4P
  • Country: sg
    • T4P
« Reply #11 on: September 02, 2012, 03:53:03 am »
http://dx.com/p/5-inch-electrical-cutter-6996?item=1
Used them for quite a while, very smooth and i can cut AWG18  :P
Thanks for the hakko side cutter advice, i'll get one and compare that with my abovementioned cutter
« Reply #12 on: September 02, 2012, 04:01:26 am »
Dear FenderBender:
--I seem to recall destroying some of those Xcelite nippers as well. But that is a good price, so I will shlep my carcass down to my local Home Depot where the parking lot is full of fly-by-nights trying to undercut the poor honest subcontractors who pay taxes and have insurance, and spend a lot of money at H.D. Why H.D. tolerates this I will never know. Eventually someone is going to get robbed or hurt, then it will stop.
"If you build a better mousetrap, you will catch better mice."
George Gobel 1919 1991
Best Regards
Clear Ether
Offline eliocor
    • rhodiatoce
« Reply #13 on: September 02, 2012, 04:25:27 am »
Even if i LOVE Lindstrom tools (cutters and tweezers), I think that for professional daily use the Full Flush cutters made by Erem are better.
I suggest you the 522N and 622N models: see detailed catalog
In general I use Lindstrom cutters only for really delicate operations like for clipping QFP pins
« Last Edit: September 02, 2012, 04:29:03 am by eliocor »
Offline T4P
  • Country: sg
    • T4P
« Reply #14 on: September 02, 2012, 04:31:28 am »
I use diamond coated deburring tips - There are titanium nitride coated ones as well as tungsten carbide coated
I do that all the time, it works great especially if you stuck some masking tape on the topside
« Reply #15 on: September 02, 2012, 04:34:20 am »
Eliocor:
--Thanks for the tip. The Erems appear to be top notch professional (which I am not, except in spirit) equipment. Could you please give us an idea of the cost for a pair?
"Noise proves nothing. Often a hen who has merely laid an egg cackles as if she laid an asteroid."
Mark Twain (Samuel Langhorne Clemens ) 1835 - 1910
Best Regards
Clear Ether
« Reply #16 on: September 02, 2012, 04:43:21 am »
Dear T4P & Robrenz:
--Indeed I take your point. A lot of the "snaggyness" is caused by my bending the leads to the side to keep the component from falling out. The masking tape (which leaves no residue behind) is a good idea.  When I am being a real fuss budget, I like to hold the component in place with my left and using a little liquid flux in situ, carry the solder to the joint on the tip of the iron.
"Thunder is good, thunder is impressive; but it is lightning that does the work."
Mark Twain (Samuel Langhorne Clemens ) 1835 1910
Best Regards
Clear Ether
Offline amspire
« Reply #17 on: September 02, 2012, 05:34:04 am »
Definitely. I would never buy an Ultra-flush Lindstrom unless I was regularly cutting wires thinner then 0.3mm.
I recommend the Micro-bevel. Most of the time, they do exactly the same job as flush cutters, but they are much tougher. The bevel is minute - perhaps 0.1mm, but the result is that the edge is very much less probe to damage.
I have a a Lindstrom 8150 cutter that I bought in the 1970's.
http://www.all-spec.com/products/8150.html
I have regularly exceeded the rated wire size without any significant nicks. That includes cutting spring steel wire. Either the steel isn't as good as it used to be, or your friend really abused those cutters. Like using them to cut high tensile fencing wire, or something similar. I often just use the cheap $15 flush cutters on my bench - like the excellent Xcelite cutters, but it doesn't take much at all to damage them. As soon as I need tough cutters, I use the Lindstrom.
Richard.
Offline eliocor
    • rhodiatoce
« Reply #18 on: September 02, 2012, 05:59:24 am »
The Erems appear to be top notch professional [...] Could you please give us an idea of the cost for a pair?
Yes, indeed: in our office they are used daily and the last time we bought them was about 7-8 year ago!!!
At this date no one of them need to be replaced.
It seems their price is from 40 to 50 USD apiece.
If you think 2 of them are too expensive, I suggest you to buy only the 522N: the head is a bit bigger than the 622N (which is smaller)
To me, the 522N is a "general purpose" cutter, the 622N is for more precise work.
Offline eliocor
    • rhodiatoce
« Reply #19 on: September 02, 2012, 06:25:18 am »
I hope from the following images you understand why those cutters are almost indestructible: I even do not remember how long I own them (here at my home lab), but except for the accumulated dirt and some minor rust spots, blades are yet perfect.
Please also take a look to the thickness of the blades in the second photo: completely different from the typical 10-20$ cheap cutters.
The following picture shows the size (in mm) of the two models (522N left / 622NA right):
« Last Edit: September 02, 2012, 06:39:47 am by eliocor »
Offline nanofrog
« Reply #20 on: September 02, 2012, 07:09:08 am »
Currently have a mixture of Erem, Lindstrom, Swanstrom, and Excelta (5 star).
  • I love the Excelta's (smooth, effortless to cut with <semi-flush>, sharp as hell, and very comfortable), but they're rather expensive, even compared to the other brands.
  • Lindstrom's RX grips are comfortable, though I'm not sure about long term reliability (feel like it takes a bit much effort cutting <standard bevel> without exceeding the max wire size, so I'm a bit nervous).
  • The Erem's are smooth (all semi flush), and cut effortlessly. Their idea of ergonomic grips (2400 series) are a sad joke though (slip and slide in my hands, even when they're dry). Better off with the standard grips IMHO.
  • Swanstrom's are smooth as well <semi-flush>, and I have exceeded their max rated wire gauge (got them used off of eBay to try, so less of a loss if I destroy them). Larger than most for it's rated wire size, so rather under-rated it seems.
+1
Most of mine are this type, the rest being standard bevels. Worst case, as others have mentioned, a good fine file can take the spike off the end of the lead.
Might have to do with the manufacture date though, as the current Lindstroms are now made in Spain (since 2004 IIRC; steel isn't as hard from what I understand, so more prone to nicks).
I have some of the newer Lindstroms, but have been too chicken to cut larger wire than they're rated for given their replacement cost.
The following users thanked this post: artvandalai
Online Psi
« Reply #21 on: September 02, 2012, 08:02:42 am »
Mine are Lindstrom 8141, they're smaller and flush http://www.all-spec.com/products/8141.html
Offline G7PSK
  • It is hot until proved not.
« Reply #22 on: September 02, 2012, 09:42:48 am »
What ever make of tool you buy make sure that it is forged rather than stamped from sheet. I have noticed that even many of the Lindstrom cutters are now stamped out of sheet as that is cheaper to make than drop forging but the sections will be thinner so that the cutting edge does not have the same support. Also don't forget about end cutters as these are often better for getting down into tight spaces.
Offline robrenz
« Reply #23 on: September 02, 2012, 01:48:15 pm »
I found this after I bought a pair of Tronex cutters.
hover over the Cutting edge technology header and there are three sub catagories.  The engineering and techincal bulletins topics are very informative.  These things are very well made.
http://www.tronextools.com/cutting-edge-technology/
Offline T4P
  • Country: sg
    • T4P
« Reply #24 on: September 02, 2012, 02:42:46 pm »
I have a cheapy end cutter and they are good for leaving flat marks but i find it is very easy to accidentally nick the solder  :'(
The fully flushed side cutters are great at leaving nice beautiful flat marks (Especially goot and hakko)
And sorry i don't know anything about european cutters
