Until REAL research comes out published in a reputable journal, I will stand here with the majority of rest of the educated scientists in the world and call this device BS.
Quite so. It appears to be a clear violation of conservation of momentum, despite any protestations of interacting with Quantum media, it's a reactionless drive. I.e., BS.
The only real test you can do, is put some solar arrays on it, put it in orbit, turn it on, and if it moves on it's own
while not touching anything else and you can get it to
raise it's orbit by any amount, it works. More likely it'll just float there and make you look silly.
Inevitably, upon peer review, this sort of thing will vanish in a puff of experimental error.
