Author Topic: Couldn't you make a film camera that was silent by rotating an array of lenses?  (Read 973 times)
Offline ELS122Topic starter
So instead of moving to the next frame, "stopping" the film for the exposure time, and then moving to the next frame. Instead move the film continuously and have a rotating array of lenses that follows the light to each frame without needing to stop the film on every time? Thereby making the camera near silent.
Offline mikeselectricstuff
    • Mike's Electric Stuff
This is how some high-speed film cameras worked, using prisms or mirrors. You probably still need a shutter though
Day Job: Mostly LEDs
The following users thanked this post: ELS122
Offline vad
Even the slightest speed mismatch, jitter, film movement in a direction perpendicular to the plane of prism rotation, or lack of film flatness during motion would degrade image quality. Resolving all these mechanical issues is possible, but it would entail enormous complexity and cost, making it impractical for the mass consumer market.
I meant for like the film industry not for the consumer market. Since many people complain how imax cameras are so loud it's impossible to record any audio on set, seeing as those cameras are very expensive already it would seem logical to use something like this if it made them more silent.
Offline vad
Well, IMAX is focused on achieving the highest possible image quality. It's likely unfeasible to achieve the same level of quality using a continuously moving film without making the camera excessively large, heavy, expensive, or unreliable.
Offline TimFox
Rotary disc shutters are often used for motion-picture cameras:
https://en.wikipedia.org/wiki/Rotary_disc_shutter
Offline vad
According to Wikipedia, the noise from IMAX cameras originates from the vacuum system. The vacuum is applied to the backplate to maintain the flatness of the tremendously large film frame during exposure.
In the case of a hypothetical camera with a continuously moving large format film, the challenge of ensuring film flatness would still need to be addressed, now for a moving film frame. This would require either finding an alternative solution without a vacuum or using the same noisy vacuum system.
Offline TimFox
Note that “full” IMAX cameras transport medium-format film (70 mm, similar to 2-1/4 inch 120 still film) horizontally through the camera, rather than the vertical transport in conventional movie cameras.
There is an interesting panoramic film still camera (modern version sold as “Widelux”, q.v.) that pivots the lens mechanically to cover roughly 150 deg.
« Last Edit: August 14, 2023, 04:02:21 pm by TimFox »
The following users thanked this post: Someone, ELS122
Well couldn't you use a centrifugal pump instead of a reciprocating one? Which could be designed to be much more silent. Or a screw type, or any other non-reciprocating pump.
Offline TimFox
What type of vacuum pump is used here now?
For this application, one does not need a “high” vacuum (very low absolute pressure) but a high pumping speed to pump air against a high leak around the film handling.
Yeah so looking at videos showcasing the mechanism of those cameras it seems there isnt even any rotating lenses, instead it's using a drum shutter and that's enough to have a continuously moving film.
So why not do this in an IMAX camera? but instead of "rewinding" the drum, just rotate it continuously 360 degrees, that wouldn't require the film to "pause" on each frame.
Offline TimFox
How would you “delimit” the frames from each other?
Well by the drum shutter of course, but since it's not a disc shutter it wouldn't distort the image if the film was continuously moving.
« Last Edit: August 14, 2023, 04:47:09 pm by ELS122 »
Offline Siwastaja
Yes, and film editing tables, too, to project the image on a screen in continuous film motion.
https://en.wikipedia.org/wiki/Steenbeck#/media/File:Steenbeck_16mm_flatbed_ST_921_(6498601571).jpg (I had the same model as pictured lying around, but gave it away. It was nonfunctional due to so much aged electronics, poor connections, capacitors etc.)
In this use case, small amount of image distortion, jitter etc. is not a problem at all.
Offline mendip_discovery
They can get up to 120db but reading an article in them they also state they use a rotating mirror to record sound...odd but I'm not a camera tech. But the sound they record is really high quality.
I think that loud cameras on set is nothing new, they just had different solutions to it back then. I wonder if it's the directors who are great visionaries but as nobody will tell them no so they want to do a wide shot and a close up but don't want any of the sound gear or film gear anywhere near the set.
I thought with the size of microphones they could hide many on set to get good sound.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Online Alex Eisenhut
  • Place text here.
IIRC that's exactly how very high-speed film cameras worked, like in the 1980s. I remember seeing some sort of lab footage from a "Star Wars" SDI experiment, and there was a vrooooup! sound just before the test, later I found out that's the rotating prism of the high-speed camera.
Well you don't hear the noise because they rarely record any audio on set, instead it's voice-overs in post production, prop sounds, etc.
