I see that some people have mentioned using these DMMs as panel meters. Are they using a battery as the power source, or have they found some way to utilise the power source that they are measuring?
Multimeter input COM(-) is not BATT(-) and you can damage the IC getting that wrong. So for panel meter use, you need isolated power, or have to make sure the common-mode voltage is reasonable. But there's no protection parts there, no coverage for CM voltage going awry, the IC will get blown up then.
A problem with these cheap DT830 multimeters is the protection components are usually left out, not populated. It depends on how cheap the build is. You have to use your eye and look for them.
A common happening is having it on Ohms but connecting to voltage like 24V. No PTC and maybe that lightbulb will cover it, but generally it will damage the DMM IC in these.
