Author Topic: Renders and Animations of PCBs  (Read 17695 times)
Offline SchottkyTopic starter
Re: Renders and Animations of PCBs
« Reply #50 on: October 30, 2022, 11:25:09 pm »
Blender Drone Animation
« Reply #51 on: March 25, 2023, 04:18:42 pm »
Starting a new series of renders and animations for electromagnetics with openEMS!
First animations shows what happens when a EM wave is launched into a coax cable with an open termination.
The following users thanked this post: rsjsouza, 2N3055, SiliconWizard
« Reply #52 on: April 26, 2023, 09:17:04 pm »
My next set of electromagnetic simulations and renders are for a 2.4GHz meandered inv F PCB antenna! I used the antenna design from Texas Instruments AN043 App note.
In this animation you can see how the surface current is distributed in the PCB antenna.
« Reply #53 on: May 02, 2023, 08:05:01 pm »
In this animation you can see how the E-Field component is formed and radiated away
« Reply #54 on: July 23, 2023, 02:25:29 pm »
Visualising the magnetic fields and calculating the inductance of a PCB coil. PCB designed by Carl Bugeja
Online SiliconWizard
« Reply #55 on: July 23, 2023, 08:01:50 pm »
Amazing work!
« Reply #56 on: July 26, 2023, 10:19:24 pm »
This animation shows what happens to the magnetic field lines of a wire loop as it is twisted. The field lines become smaller and loop over a smaller area. Twisting wires and cables is beneficial in reducing interference. Created using Electromag nodes in Blender!
« Reply #57 on: September 07, 2023, 11:12:55 pm »
Texas Instruments Bidirectional DC-DC Converter Reference Design for 12-V/48-V Automotive Systems
The following users thanked this post: rsjsouza, 2N3055, SiliconWizard, Kim Christensen
« Reply #58 on: December 20, 2023, 11:45:23 pm »
You can create words on a calculator with a 7-segment display by entering certain numbers
This animation shows the words you get when entering numbers 0.7734, 5318008 and 7734206 and then reading the display upside-down!
« Reply #59 on: March 21, 2024, 09:43:02 pm »
USB-C PD 65W Charger
« Reply #60 on: March 21, 2024, 09:46:31 pm »
Visualising Clearance boundaries and violations
Offline kimera
  • Country: la
« Reply #61 on: July 13, 2024, 05:23:39 am »
Hi All, I would like to share some renders and animations of some of my PCBs. I've tried including as much detail as I can, such as cables, connectors, solder joints, and probes. I think creating these types of renders can help a lot when you are presenting your work to others and to show how everything works together, and also showing off  8) . The 3D viewers in Altium and Kicad are great, but I feel more can be done.
These PCBs were designed in Altium, all the 3D models were created in Blender, no STEP files. Let me know what you think
I would like to do that too, can you teach me or give me the steps to render so I can find the information for each step to try it out? I am currently using Altium 21 and 3D step files.
Thanks you.
