This is an home made Gamma match dipole .
The length of the fat tube , can tell the frequency that it was built for.
The construction look heavy , so it can handle about 2KW RF ,
looks to was serving for an "point to point" transmitting link .
The pipe that holds the " Antenna " ( missing from the picture ) , it should act as the negative pole of the dipole.
Still the permanent adjuster on the capacitor , look like that it was build more as an experimental , than an usable item .
