Author Topic: Will going through undergraduate textbooks allow me to design my devices?  (Read 3585 times)
Offline SerieZ
  • Zap!
I heard a cone shape device made out of a silvery ductile metallic element found primarily in bauxite worn around the head is the most effective against such unwanted implants.
As easy as paint by number.
Online MK14
An example of delusional thinking, then, might be a patient thinking that the CIA has secretly implanted a computer chip in his or her brain. Although the delusional patient can have a head x-ray or magnetic resonance imaging (MRI) that would prove that there is no chip, he would continue to insist and react to the notion that a chip is implanted, and that the head imaging must have been wrong, or even that the chip might have been invisible to MRI detection.
http://www.nathanlavidmd.com/psychiatric_descriptions/schizophrenia.html
The very reason that the quote doesn't consider the possibility of x-ray or scan information being fabricated proves that you are spreading disinformation and psychiatry is a stupid profession existing only to turn people into puppets and slaves. The patient who is intelligent enough to argue that the imaging must be wrong or the implant was invisible, would have also been able to argue that the x-ray or scan information might have been fabricated, the fact that such a counter argument from the patient hasn't been mentioned or presented as it wasn't made is really the most conclusive proof of the psychiatric professions subversive motives.
The quoted TEXT, is only giving a generalised example. It is not supposed to be trying to cope with all the millions of possible, real life variations in things.
E.g. I might say to you "Turn the POWER Switch OFF, Please".
There are all sorts of situations that this could apply to. But there are rarer ones, which I might not have considered. Such as the switch might be broken, or you can't find the on/off switch, or even that there isn't an on/off switch for this device.
Just because I didn't cover all those thousands of different (unforeseen) options, DOES NOT mean, all of the type of person that writes text like that, is bad. It is just because there are limitations, on how much information you can convey by written text messages.
I would suggest you get professional help. Ideally via professional Doctors, who can help the situation.
If that is not possible, in your circumstances. Then confide in your most trusted, reliable and wise close relative, friend or work colleague.
« Last Edit: July 30, 2020, 01:07:53 pm by MK14 »
Offline Ysjoelfir
Psychiatrists are great group of people, really?
Absolutely.
Yes, MRI(assuming it works as it should) seems like a good thing to disable my implant. Almost all parts of circuits can become magnetic when current flows through them but their magnetic power isn't that much. With the knowledge you are showing, I'm surprised you actually considered the possibility of it getting pulled out. I should be worried about that risk nevertheless, if it got pulled out of my ear region or throat region, I don't know what kind of damage it might cause.
Can you show photos of your implant?
The magnetic forces in such a circuit are minimal. In my implant there is a pretty substantial antenna, so basically a coil. The forces aren't enough to be even noticable.
Pics (one with the syringe before the action and one after its done):
https://drive.google.com/drive/folders/1qcJt0dKuBP1nqvuuu6NFEB4ue4_Hi-go?usp=sharing
I was certain that I took a video while that thing was put inside me, but I can't find it. But I can remember that it was pretty painfull and not easy to get in.
This is how it looks like: https://dangerousthings.com/wp-content/uploads/promo_x-series-2mm-tag-416x416.png
What kind of circuitry is it, how is it powered, how does it receive data and what frequencies does it use?
RFID emulator chip with a few bytes of data storage, powered by RFID, receives Data by RFID and uses 125 kHz.
Greetings, Kai \ Ysjoelfir
Offline DrG
Absolutely.
It looks to me (and please correct me if I am wrong), that you have, what is similar to, the common pet chip RFID https://science.howstuffworks.com/innovation/everyday-innovations/pet-microchip1.htm
There are legitimate medical reasons to use these. I have not read the thread real carefuly, but I am not sure that is the issue. Nevertheless, you make a point so thank you for that.
- Invest in science - it pays big dividends. -
Offline james_s
I knew two different people since gradeschool who later developed schitzophrenia in their early 20s and this is exactly the sort of stuff they talked about. One of them was posting prolifically on facebook back when I still used that, as in every 10 minutes for hours at a time about the various people tormenting her and secret agencies spying on her, it was really bizarre. The other one I knew thought his whole family was in some kind of conspiracy against him, occasionally he would be on medication for a while that settled him down but it also took all the life out of him and made him a bit of a zombie while he was on it. Schizophrenia is a really scary disease, people who have it tend to resist any form of treatment because they genuinely believe that they are sane and that people who are trying to help them are out to get them.
The following users thanked this post: tooki, MK14
Offline Ysjoelfir
You are absolutely correct :)
And I deliberately chose to get that thing. Its pretty useful.
And no, surely that is not the issue. I just wanted to show to novicefedora that there is nothing bad in having an implant, as I did that to myself.
And yes, I know exactly what you and every other person that answered here is thinking. And I agree. ;)
Online MK14
It's sad, when things like that, happen to people you know. Especially, if you knew them, before such episodes, started. I would guess, that the modern era. With many things open, 24 hours a day. Easy/quick internet searches, even if the search terms are crazy. Massive anonymous communications medium, such as this forum.
It could make things like that worse (but there are also ways, it could make it better).
It is not immediately obvious, which wins out. I.e. If modern times (now), is better or worse than say, 20 or 30 years ago. As regards, mental health and getting mental health issues sorted out.
My understanding, is it has never really been any good (for the patients), at any time, really, so far.
Maybe, in the future, diagnosis and treatments, will get better. One has to just hope, I guess. It seems to be a relatively neglected part of society, medicine and can cause sometimes negative feelings in others, if they know about other peoples, mental health conditions.
There is still varying amounts of stigma/negativity, both at the individual level and society level, about mental health and/or seeing/dealing with Psychiatrists, and other mental health professionals, such as Psychologists and Mental Health Nurses.
Both me, my imaginary friend, and all my other alternate personalities, all agree that I have no such problems.  :-DD
« Last Edit: July 30, 2020, 08:42:04 pm by MK14 »
Offline cdev
Some of the women who are trafficked into sex slavery (according to the police in at least one US state, North Carolina) are tattooed with barcodes. Can RFID implants be far behind?
Scary if its true.  It might be. Powerful people are involved in sex trafficking.  But I doubt if the technology exists to control people via brain implants, yet. If it did we would likely know about it.
Offline free_electron
    • SiliconValleyGarage
You need professional help. Please consult your doctor..
Preferrably a brain surgeon .. I hear Gag Halfrunt does excellent work
Online langwadt
and occasionally when not treated they end up murdering random people they think are part of the conspiracy ...
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
As you can see by my use of my helmet, I can not only stop emissions from getting out but also in as well. Please construct a similar helmet. Your troubles will soon disappear.
Voltage does not flow, nor does voltage go.
Offline cdev
When I was growing up I had a very good friend, Jeff, who was very smart, but it turned out that just like you describe, he had schizophrenia, which I think was either triggered or aggravated by drugs. After I moved away he apparently had a psychotic break. When I returned for a couple of days I called him up and not knowing what was going on suggested we spend the day in NYC since that was something we both had done a lot of previously. We did but when we got there on the subway he started acting really strangely, he was obviously seeing things that were not there! I didnt know what to do and he darted out of the subway as the doors were closing and I got separated from him. Anyway, that was the last I ever saw him, a few days later I had to leave town and some time later I heard that he had committed suicide by stepping into the path of a train.
Whats strange is that his family never admitted that he had classic schizophrenia (which was probably treatable)
The following users thanked this post: MK14
Offline westfw
So I have to read graduate and post-graduate books to actually build something useful?
I would say that you have read stuff OTHER than "text books."  Data sheets, App Notes, technical blogs, commercial and open source schematics, hobby magazines, QST, Ham Radio publications, source code, scholarly and practical research papers, and advertisements.   Books and magazine articles (from Elektor to IEEE Transactions on XXX...)
I only took a couple of "graduate" classes (the ones that were open to undergrads as well), but AFAIK, they're still very theoretical (possibly depending on which school you're talking about.  You go from integral/differential calculus to tensors and discreet math.  Whee!)
IMO "Text books" by their very nature address mostly theory, and the stuff that doesn't change much from year-to-year (since publishing a textbook, and developing a curriculum based on a textboot are both rather lengthy propositions.)
(I did notice, back ~1980, that Lancaster's CMOS cookbook appeared in the U bookstore.  "oh!  What class gets to use THAT!", I wondered...  It was a graduate chemistry class about "designing and building lab equipment."   Hmmph.)
Online MK14
***stuff***
The OP has been BANNED.
Presumably because of attempting to create dangerous devices and/or rudeness at times and/or because they are having *difficulties*.
Offline Zero999
  • 0999
***stuff***
Perhaps this thread should be locked? Especially if the ban is permanent.
