Author Topic: Just blew up a battery  (Read 9164 times)
Offline MrOmigoodnessTopic starter
  • Problem?
« on: March 28, 2012, 10:16:56 pm »
I was messing around with some spare components and the 9v battery I was using blew up. It sounded like a gunshot, almost scared me to death. Then I was about to pick it up and it blew again. Oh, and it almost burned my table (and my hand). Whatever, I guess the best way of learning is to fail. And speaking of failing, I wanted to recommend anyone starting out with electronics to watch this video it really gives you some motivation to keep trying. Cheers  :D
~MrOmi~
Offline IanB
Re: Just blew up a battery
« Reply #1 on: March 28, 2012, 10:21:11 pm »
9 V batteries don't really do that (really, they don't).
What kind of battery was it, and what were you doing with it?
« Last Edit: March 28, 2012, 10:30:06 pm by IanB »
Offline Psi
« Reply #2 on: March 28, 2012, 10:28:27 pm »
The only way i can see it exploding is if you overcharged it
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: March 28, 2012, 10:30:57 pm »
I'd think it's plausible that a new 9V battery could pop if shorted - there are different constructions - some are made of six aaaa cells, and these could potentially build up a fair head of pressure.
However reverse charging it would be a more effective way of detonating it 8)
Day Job: Mostly LEDs
Offline IanB
« Reply #4 on: March 28, 2012, 10:31:17 pm »
The only way i can see it exploding is if you overcharged it...
...by connecting it to the mains, or by connecting it to a 12 V car battery...  :)
  • Problem?
« Reply #5 on: March 28, 2012, 10:41:42 pm »
Really, it did. I'll post some pics if you want.
Offline Psi
« Reply #6 on: March 28, 2012, 10:47:06 pm »
We believe you, it's just that 9volts are low power batteries.
It seems odd that one could build up enough pressure on its own to explode like a gunshot.
  • Problem?
« Reply #7 on: March 28, 2012, 10:50:06 pm »
I don't wanna start a fight here so I'm just gonna leave it at that :)
Offline Time
« Reply #8 on: March 28, 2012, 11:02:45 pm »
I put a 9 V in my pocket with some change once and it got hot hot.  Thats about the most danger I've ever seen one present.
-Time
Offline IanB
« Reply #9 on: March 28, 2012, 11:05:23 pm »
I didn't ask for pics, I asked what kind of battery was it and what were you doing with it?
Offline Kilroy
« Reply #10 on: March 28, 2012, 11:08:14 pm »
I'd think it's plausible that a new 9V battery could pop if shorted...
Yup.
Just hook the battery up to a low value resistance and wait for it...
The fool generalizes the particular; the nerd particularizes the general; some do both; and the wise does neither.
Offline Mint.
  • Account is inactive now. Thanks everybody!
    • Personal Blog, Mint Electronics.
« Reply #11 on: March 28, 2012, 11:38:46 pm »
I'd love to see the pics just for the lols ;D
Personal Blog (Not Active Anymore), Mint Electronics:
http://mintelectronics.wordpress.com/
Offline TriodeTiger
« Reply #12 on: March 29, 2012, 05:15:02 am »
Ones I've seen always have a plastic bottom, to blow off first (or assemble without welding, either way) - can perfectly imagine they put it there for a reason.  ???
"Yes, I have deliberately traded off robustness for the sake of having knobs." - Dave Jones.
Offline westfw
« Reply #13 on: March 29, 2012, 05:50:11 am »
I've had individual AAAA cells extracted from a 9V pop their end off when discharged too heavily.  I always thought that the extra containment of the output package would prevent this, but it's believable that one would pop anyway...
Offline amyk
« Reply #14 on: March 29, 2012, 12:30:50 pm »
I had this happen with regular alkaline AAs too with heavy discharge (>2A bursts).
Offline T4P
  • Country: sg
    • T4P
« Reply #15 on: March 29, 2012, 01:42:31 pm »
The ones with individual AAAA cells are Alkalines
So and so , the solid ones are definitely carbon zinc .
« Last Edit: March 30, 2012, 04:50:56 pm by Dave.S »
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #16 on: March 30, 2012, 09:48:23 am »
9V batteries have such a convenient form factor that allows you to easily connect two of them together  ::) :P
Offline Psi
« Reply #17 on: March 30, 2012, 12:00:30 pm »
or 52 of them!! :P
Offline westfw
« Reply #18 on: March 30, 2012, 03:34:36 pm »
Most of the 9V NiCd or NiMH batteries I've taken apart use flat (oval) coin cells stacked on one another (and usually separable.)  Frequently 7 of them (8.4V) rather than 6.  (The AAAA configuration only works with 6 cells.)  There's actually a surprising amount of variation in the internals of 9V batteries...  (9V "ultra" lithium batteries seem to have a single molded plastic module with three internal cells.  A shame that they're not separable into 3V cells; those might have filled a nice niche in the battery space. (bigger than coin cells, smaller than camera batteries...)
Offline Ajahn Lambda
  • quecksilberdampfgleichrichter
« Reply #19 on: March 30, 2012, 04:40:56 pm »
Still waiting for those pictures.   :D
Offline T4P
  • Country: sg
    • T4P
« Reply #20 on: March 30, 2012, 04:50:07 pm »
How about 2196Volts .
