Author Topic: SPOT THE DIFFERENCE game  (Read 1253 times)
Offline BlownfuseTopic starter
« on: June 11, 2024, 03:01:04 am »
I hope to post a weekly Spot The Difference challange. I hope you will like them, even if it frustrates you  ;)
Under the image is a link that will reveal the differences.
#1 The bottom image has 10 alterations. Can you spot them.
Sorry, but I do not know how to leave a link that requires to be clicked to open. This forum seems to automatically open it for all to see prematurely.
If there is no solution to this 'Blownfuse' I will just have to post the 'differences image' just before I post another game next week.
Okay, I found out via @tautech about adding a thumbnail that is expandable. So here is the differences...
« Last Edit: June 12, 2024, 10:45:42 am by Blownfuse »
The following users thanked this post: pcprogrammer, Kim Christensen
Offline Kim Christensen
Re: SPOT THE DIFFERENCE game
« Reply #1 on: June 11, 2024, 03:40:36 am »
Found 8 of them... Can't find the last 2.
EDIT: Found 1 more... One to go.
EDIT2: Got all 10.
I must say, you're pretty good with the photo editing. What program do you use?
« Last Edit: June 11, 2024, 03:52:07 am by Kim Christensen »
The following users thanked this post: Blownfuse
Offline Halcyon
  • Global Moderator
« Reply #2 on: June 11, 2024, 03:52:47 am »
The flipping of R70 was sneaky ;-)
Offline Psi
« Reply #3 on: June 11, 2024, 04:27:20 am »
A missed opportunity to rotate one of the screws 20deg.
I got 7 and then had to get back to work.
« Last Edit: June 11, 2024, 04:30:32 am by Psi »
Offline pqass
« Reply #4 on: June 11, 2024, 04:32:16 am »
10 for 10.  What do I win?
Offline georges80
« Reply #5 on: June 11, 2024, 04:36:31 am »
That would be L3...
Online DimitriP
« Reply #6 on: June 11, 2024, 05:05:11 am »
the immense satisfaction that what a machine can do in a few milliseconds...you can do too !!!
Offline pqass
« Reply #7 on: June 11, 2024, 05:12:19 am »
Yes. I can derive satisfaction from solving a pointless puzzle.  I don't believe the machine ever will.
Online DimitriP
« Reply #8 on: June 11, 2024, 05:21:52 am »
I'd rather spend the time figuring out how to get the machine to solve the puzzle than solve the puzzle :)
« Reply #9 on: June 11, 2024, 05:38:07 am »
EDIT2: Got all 10.
Mostly GIMP
The following users thanked this post: Kim Christensen
« Reply #10 on: June 11, 2024, 05:39:14 am »
The satisfaction that you are not upset for not finding them all. :D
Offline pcprogrammer
« Reply #11 on: June 11, 2024, 05:47:37 am »
 8)  That I was looking for, but no not there.
Nice job. Some were difficult to spot, but I found them all.   :-+
« Reply #12 on: June 11, 2024, 05:51:29 am »
EDIT2: Got all 10.
Mostly GIMP
I guess the bend capacitor is done with real life photography.   :-//
Offline pqass
« Reply #13 on: June 11, 2024, 05:56:41 am »
Can you do that in 21 hours or less?
Offline pqass
« Reply #14 on: June 11, 2024, 06:12:52 am »
So there is only risk of losing.
I guess the only winning move is not to play.
« Reply #15 on: June 11, 2024, 06:20:15 am »
The win is that it is good for your brain.
Offline BrianHG
« Reply #16 on: June 11, 2024, 08:27:31 am »
Careful, I saw a review about an AI which learned to play 3D games by analyzing the game's visual display output.  It was a review on the YouTube channel '2 minute papers'.  In the test game, one of the walls/surfaces had an optional video ad playing in it.  It was accidentally discovered that the AI would stop it's player movements at these AD playing walls and stare into them, basically being addicted to what it was seeing.  One could say that the AI PC player was enjoying itself staring at TV commercials.
« Reply #17 on: June 11, 2024, 09:27:47 am »
Basically not much more than your average couch potato.  :-DD
« Reply #18 on: June 11, 2024, 10:47:08 am »
EDIT2: Got all 10.
Mostly GIMP
The bent cap is original, it was replaced by C271.
Offline BrianHG
« Reply #19 on: June 11, 2024, 03:57:17 pm »
EDIT2: Got all 10.
Mostly GIMP
Easy enough to tell as C271 has a melted solder burn through it's plastic just above it's right leg.
2 different caps wouldn't have the same melted plastic burn.
If I were to replicate this game, I would have been able to replicate all the edits with my old PaintShop Pro 6 from 1999.  It's stencils brushes with feathering blended edges and multi-layers would do the trick.
I know Adobe Photoshop Elements which came with my laptop could also do it, but I am too lazy to learn how to use it.
« Reply #20 on: June 11, 2024, 04:40:12 pm »
EDIT2: Got all 10.
Mostly GIMP
After I wrote the post and looked at the images again I realized this to be the case. At first I figured it the other way round, that the bend was in the changed image and that would have been very good editing indeed.
« Reply #21 on: June 12, 2024, 10:47:18 am »
I attached a thumbnail image of the differences to the original / first post.
Thank you all for your patience.
« Reply #22 on: June 12, 2024, 09:42:28 pm »
#2 SPOT THE DIFFERENCE
The right hand image has 10 alterations. Can you spot them.
« Last Edit: June 13, 2024, 03:09:32 am by Blownfuse »
Offline BrianHG
« Reply #23 on: June 12, 2024, 11:43:11 pm »
Unless you count the 4 separate missing reflection streaks on the brown loop of wire as 4 separate changes, I only found 6 changes.
Also, I think you posted the wrong answer message as it is the answer to a different puzzle.
« Last Edit: June 12, 2024, 11:45:57 pm by BrianHG »
« Reply #24 on: June 13, 2024, 03:07:22 am »
OH NO!
Thanks for telling me. I will correct that now.
