Author Topic: Is there a use for High Precision Voltage Supplies for a normal Hobby User  (Read 587 times)
Offline reklmTopic starter
Offline The Doktor
What exactly do you mean by "precision"?
The following users thanked this post: Geoff-AU
Offline Sal Ammoniac
Do you mean something that you can use to calibrate a DMM or something to power a project?
"That's not even wrong" -- Wolfgang Pauli
Offline m98
Please define “High Precision” and “Hobby user”. If you mean a good, linear lab power supply with like 100 mV/10 mA accuracy and < 10 mV noise, probably any hobbyist who does anything related to analog electronics.
Offline Messtechniker
I'm in the market for a dual, variable, current limited power supply (0 to say +/-120 V +/- 100 mA)
which will not cost an arm and a leg. Want to test high voltage opamps
which are becoming more popular. Will probably have to build such a PSU myself.
Google didn't turn up with anything in the low cost range. However, there are some possibly useful circuit schematics floating around.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Offline Stray Electron
  Almost certainly.  I started with very cheap unregulated Radio Shack PSs and then went to regulated supplies by HP, Lamda and similar companies and finally to the Precision PSs made by HP and others.  As your knowledge and skills increase so will your need for more precise voltages. Particularly when you want to use a supply not as a "power supply" as a substitute for a voltage inside of circuits for troubleshooting purposes.
  The better power supplies also usually feature current limiting which is also very handy when troubleshooting problems in a device. Judicious use of current limiting can prevent burning up equipment that has shorted capacitors or other shorted components or if you accidentally short out something while probing a circuit.   I keep notes on everything that I work on and also include a note about how much current the device draws under normal conditions. Then the next time that I work on something similar I set the current limit of the power supply just slightly above that.
   I don't use my Precision power supplies for general use but I do keep them on hand for the times that I need more precision than what an ordinary supply will give me.
   Check out the HP 6104A, 6105A, 6114A 6115A and related Precision Power Supplies. They're old but still in very high demand.  The manuals for those are very detailed and you can learn a lot by reading them.
Online tggzzz
I rather like my Precision Designs 2020. 0-20V, 2A
LM399 based, 1mV steps, trimpot can give 10µV resolution in 10V - albeit with a little drift, so 50µV short term is a more realistic spec.
