I know I'm over thinking this...
Is it possible to add a resistor in series with a wire/circuit using a transistor?
Im currently using a small trimpot to add a variable resistance in series with a circuit / wire, but instead of having to manually adjust it carefully periodically from adding between 80ohm - 100ohm I just want to use an Arduino to control a few transistors to either add a 80ohm, 90ohm, or a 100ohm resistor in series.
But I can't for the life of me figure out how use the transistor to put the resistor in series! I've already built the circuit but I wasn't paying attention and I'm adding the resistor in parallel which is obviously not what I'm trying to do....
Thx
