I don't have that Actiontec, but I do have that Trendnet, a set of TP-Link, and a set of Zyxel. Of the three, the Zyxel performs the best because it has gigabit (and is much newer), but the TP-Link did much better than the Trendnet despite having basically the same specifications.
Teardown of the TP-Link:
Teardown of the Zyxel (modded):
BTW, if you have phone wiring that is not being used for DSL, you can hack the adapters to run on it and get very good performance. Using the Zyxel adapters, I managed to get as much as 600Mbps over some old phone line.
I wouldn't recommend the Trendnet since in addition to not performing as well as the TP-Link of the same specs, it uses a nonisolated power supply design that makes it extra work to hack for running over phone line.
