Probably the internal die is too big to fit in the smaller leadpack, so they put it in one that fits, even though they have so many unused pins. The lower pin count frame has more metal inside the package, and probably they could not fit the internal spacing and route to the bonding pads on the die with the 14 pin leadframe. to fit. As well the other packages use less plastic filler and are thinner and thus lower cost.
