Well in this instance I want it to be reversible, typically i'd just damage the JTAG.
Epoxy is straightforward to remove, if you use the hard epoxy it risks shrinkage and causing damage. the temperatures are fairly extreme, so especially on the teeny SMD stuff. It never bonds that well I find. But the reversible thing applies to that too,s o even if I could make it so that it was impossible to remove , it'd be no good.
cheers though.
