Author Topic: Industrial Wireless Angle Sensor Recomendation.  (Read 279 times)
Offline rvalenteTopic starter
  • Country: br
« on: November 27, 2023, 02:36:01 pm »
Hello Mates,
Im looking for some advice here
During the differential hub is assembly production is necessary to check the pinion-ring ratio, the ring is driven (with diff locked) by the nut runner for 15 turns, need to read the pinion turning angle (red circle on picture)
I was thinking about a wireless and gyro based angle sensor (encoder), would assembly it to a jig, magnetically coupled, operator would pop in, drive the ring, the pinion rotates and its measured, pops out, next.
I've not found any industrial sensor for this demand, what would you guys suggest me? I'm not looking to dev anything, prefer to apply, single use only.
Greeting, Renan
