To the original poster.
I worked in induction heating for short period in the early 80s. I worked for a company called Radyne, which is now part of the inductotherm organization.
The fundamentals for induction have not changed since then:
1) Good conductor like copper, gold, silver are difficult heat. This is because they have low resistance.
2) High frequencies, around 50kHz are used for small components like the teeth on a saw blade. Power levels 10-20kW
3) Medium frequencies 10-20kHz are typically used for something like an alternator shaft, say 0.5 inches (1.25cm) diameter. Power levels 50kW
4) Lower frequencies are used for melting furnaces and billet feeders. Power levels 300kW to 3MW.
5) The higher the frequency the smaller the penetration of the heating, this comes from the skin depth.
6) For hardening applications, power density is important. You want to be able to heat the material fast enough to change the properties on the outside of the material without changing the properties of the inside.
Have a look at this website:
http://www.inductotherm-hwt.co.uk/content/home/#startAnd this brochure:
http://inductotherm-hwt.co.uk/assets/content_pages/352593555_IHWT_Power_Supply_Brochure.pdfFor the size of material you are talking about, I suspect that your best plan is to outsource this to a company that specializes in this.
Good luck !!
Jay_Diddy_B
