I've replaced all of my incandescent bulbs with LED bulbs (a few years ago) and they have been flickering randomly. Now before you jump down my throat for not just googling it, let's assume I've googled, explored, and tested all possible reasons why LED bulbs flicker. So without furthor ado here is the data:
1. When the bulbs flicker, its a regular pulsing at about 60hz ("eye balling it").
2. All bulbs on the same circuit (as in powered from a single switch, maybe not an actual branch circuit) flicker in unison. Also bulbs from different manufactures on the same circuit. Although I haven't taken them apart to see if they use similar driver circuitry.
3. The flickering is extremely noticeable, like when it happens its obvious and distracting and guests go..."what was that"?
4. The flickering happens for 5-20seconds
5. The flickering is random. I may not see a circuit flicker for days, then it will flicker twice in a hour.
6. Some circuits constantly flicker when they are dimmed low. This flicker is barely noticeable, but its there.
7. ifferent bulbs installed in different types of outlets with different types of dimmers. For example. Most of the bulbs I purchased were expensive Cree bulbs. I've since then purchased some sylvania and GE dimmable bulbs. All experience the same random regular flicker
8. Most of my cuircuits are on phase chopping AC dimmers. However I've purchased compatible dimmers mentioned on Crees website by part number with no improvement. Circuits without dimmers also experience the issue
9. I built a 12V 50Amp RGB lighting system for my deck using water proof LED strips. I used a high quality Dell server power supply with n channel mosfets. Fully custom built, soldered, and programmed by yours truely. Still experiences some slight flickering.
10. I have LED fluorescent replacement bulbs purchsed from AliExpress with in-built drivers (BTW I highly recommend Sunway Lighting store). Still a flicker.
11. My voltage is ~123V at 60.00hz everytime I've measured it.
I need to ask my neighbors if they have the same issue to see if its noise from the power line. Our high voltage(750KV) comes down from the high tension wires about 1 mile away. The 35KV line travels about half a mile from the sub station, then disappears underground for neighboorhood distribution. In between the sub station and the penetration for underground there is a foundry that I just happen to know uses induction heating to smelt its metal. I'm talking like...SERIOUS power draw. Use google maps and search for Timet in Morgantown, PA. You'll see the sub station just NW of their property with houses just south of their property. Is is possible our neighboorhood could be experiencing some noise when they turn that thing on?
One of the things I want to try is when my family goes to bed monitor a circuit that is flickering and turn off one circuit at a time to see if a piece of equipment in my house on some circuit is causing the issue.
Any additional thoughts would be useful Thanks!
