Author Topic: Recommended handheld DSO for automotive work  (Read 2832 times)
Offline SynopticTopic starter
« on: September 26, 2017, 12:57:38 pm »
Hi EEVBlog! I am looking to buy an inexpensive handheld oscilloscope mainly for working on low voltage in automobile or other low voltage/low frequency mini projects.
I read about the Nano, ut81b, used fluke 123 and used THS720.
I already own a bulky Leader 40Mhz 2ch Analog scope but I am not scope savvy.
Right now I need something to analyse the waveform of the ignitor output.
What should I be looking for features/capabilities?
Any recommendations?
Thank you!
Offline Deridex
  • IMHO
Re: Recommended handheld DSO for automotive work
« Reply #1 on: September 28, 2017, 06:24:34 pm »
Well i only saw 2 handheld osciloscopes so far:
The already mentioned Fluke and the Keysight U1600 Series.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #2 on: September 28, 2017, 08:40:27 pm »
Perhaps take a look at the UNI-T181A? One of the resident experts joeqsmith did a review.
Offline Lightages
  • Canadian po
« Reply #3 on: September 28, 2017, 09:28:24 pm »
This might, MIGHT, be a good option. I have no experience with it:
https://www.eevblog.com/forum/testgear/has-this-been-discussed-before-a-'decent'-portable-oscope-for-$70/msg1302870/#msg1302870
Offline Johnny10
« Reply #4 on: September 28, 2017, 11:34:17 pm »
I had my first bit of learning on auto ECM.
Fuel Injectors Voltage and Current.
Cylinder compression, I built my own pressure transducers.
Fuel Pressure gauges.
1000:1 Spark probes
You need a good current probe. For battery, Fuel pump, Fuel injectors.
I bought the Snap-On.
Bought a Rigol 50 megahertz scope 1052 I think could set it under the hood without many problems.
It did everything that was needed. But was a bit inconvenient really not meant for under the hood environment.
After a while I purchased a Snap-On Verus Wireless at auction.
I want to pick up a Fluke 199C for the future use.
Believe they are more robust than most.
Something you want to be aware of.
Brightness of display is of utmost importance.
« Last Edit: September 29, 2017, 01:48:35 am by Johnny10 »
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline Johnny10
« Reply #5 on: September 29, 2017, 01:53:43 am »
I would recommend a USB scope like PICO but you would need a laptop to go with it.
And let me say, you don't want a lot of dangling wires floating over the engine compartment. Yikes.
I think I pulled together my first kit including probes for under 500.
After learning all the ins and outs I sold the Rigol for 20 less than I paid.
And bought the Verus.
Which was way over priced for the 3Mhz oscilloscope that was integral to the scanner software.
Offline Johnny10
« Reply #6 on: September 29, 2017, 02:07:39 am »
Looking for low cost? Fluke 123's are good but like I said, look for screen brightness.
Hard to see most any screen in the sunlight.
What good is it if you can't see the waveform?
Also make sure you can get the waveform out to a PC so that you can analyze later.
Use cursors to measure RPM times and high voltage. How long is Fuel injector open?
You are also going to want to keep a database of waveforms for future reference.
