Author Topic: What type of temperature sensor is this?  (Read 900 times)
Offline MrOmnosTopic starter
  • Country: np
  • BE in Electronics and Communication
« on: April 12, 2018, 04:27:19 pm »
So, a 3D printer at our school is having issues with hot bed temperature. It is just showing random temperatures. Sometimes it shows 300C but when you touch the board its barely warm. I checked the cables to the temp sensor and they are fine. Also did the continuity test. So, I think the temp sensor needs to checked. I would like to check it with an arduino but I haven't worked such temp sensor before. Looks like some kind of thermo couple. There's also a LM358 on the main board where the temp sensor connects, also a bunch of resistors. So, I assuming it is a resistor bridge and op am set up. But I am not sure. I wanna be sure before I do anything to it because if I break it is gonna take a month to get spare parts and everyone waiting in line to use the printer is gonna get angry. Does anyone know what type is this so I can look up a tutorial and hook it up to my arduino real quick and test it.
the thing on the right is the heating element and one on the left is temp sensor.
« Last Edit: April 12, 2018, 04:29:12 pm by MrOmnos »
Offline Horusaem
Re: What type of temperature sensor is this?
« Reply #1 on: April 12, 2018, 04:33:21 pm »
Why not google the 3D printer you are currently using to try  to get Bill of materials for it ? <--- a Rod ;)
Offline sokoloff
« Reply #2 on: April 12, 2018, 05:32:56 pm »
It is most likely a thermistor.
Thermocouple would have two different types of wires evident, generally with different color insulation.
A "one wire" sensor would probably have 3 wires (though it can work with only two).
A thermistor in a resistor bridge is the most likely thing here. Looking at the BOM for the printer (if open source) is obviously the best path.
