I agree with you. I was just bothered by the statement:
never been able to sustain the published rate for any model of HDD. Always 10-15% lower. Seagate ones I've seen 60% down (they've had some horrific firmware, there's a reason I won't buy them).
10-15% lower at 144 MB/s would be 115-120MB/s which obviously isn't the case here. Mine is within less than 5% out, and it's possible larger drops would be caused by bad sata drive controllers/chipset implementations, not the hard drives.
60% down would be just ridiculous.
Again, they never claim throughout the disk surface, they just say "
UP TO ### MB/s", just like your ISP says you have up to 100 mbps internet download speed or whatever speed they advertise.
Either way, it's totally pointless to brag about the maximum speed, because once you get multiple i/o on the disk, the transfer speeds go down.
Luckily, when doing video encoding, most stuff is sequential, so as long as you read from one drive and save to other, you can get high speeds, high enough it doesn't matter what drive you use (unless you work with lossless hd or --- damn i just can't remember the term now and I work with this stuff at least once a week --- pre- bluray mastering stuff, 200-500mbps content, RED/10bit h264 lossless etc)
