Hello,
I'm trying to make a parameterized version of the OPA189/OPA2189 from the datasheets.
B2 spice has a parameterized opamp that you can plug in values.
I can't seem to understand how I can get the frequency of the poles (zero, 1st, 2nd, 3rd, & 4th) from the datasheet, and I also need the "dc differential mode gain" which doesn't seem to be in the datasheet.
Also, I know this is not probably either but which type of "input (type n or p)" does the opa189/opa2189 most likely resemble?
Any help would be appreciated.
Thanks.
