Author Topic: Workbench lash-ups ... The Battery holder  (Read 1043 times)
Offline BrumbyTopic starter
« on: August 27, 2020, 06:07:40 am »
Have you ever had a battery you needed to connect to - like NOW - but not had the right holder for it?
What have you done to address the lack of time to do anything but work with what is within reach......?
Here's my contribution from today - an A23 12V:
A couple of M5 bolts stuck through the package they came in, with a nut for gap adjustment.  Worked much better than I had hoped.
Has the additional benefit of accepting eye terminal connections with a few extra nuts.
« Last Edit: August 27, 2020, 06:12:22 am by Brumby »
The following users thanked this post: AdrianFu
Online Ian.M
Re: Workbench lash-ups ... The Battery holder
« Reply #1 on: August 27, 2020, 06:13:54 am »
Heh.  That's much better than the usual rubber band round the battery long-ways, with a spare set of meter probes stuck under it.
Online ledtester
« Reply #2 on: August 27, 2020, 06:21:42 am »
There are some ebay/aliexpress offerings for this... search for: "4 wire battery holder" or "4 wire battery stand":
1054952-0
1054956-1
« Reply #3 on: August 27, 2020, 06:41:41 am »
Yeah ... I don't have any of those laying around.
Very fancy.
Online Ian.M
« Reply #4 on: August 27, 2020, 07:08:27 am »
Yes, that's overkill for anything except precision cell testing.
Fancy is usually any hard plastic tube you have handy that's a reasonably good loose fit for the battery diameter, with a couple of holes in it for nails across it.  A conical spring for contact pressure is nice, but at a pinch, a bit of aluminum foil wrapped round a chunk of closed cell foam will do.  It gets a bit unwieldy if you want 12V as for an AA pack that ends up being about 17" long!
Offline mcinque
  • I know that I know nothing
« Reply #5 on: August 27, 2020, 01:42:26 pm »
Magnets and wires soldered? Maybe they doesn't allow too much current, but they works fine
Offline Mr Evil
    • mrevil.asvachin.com
« Reply #6 on: August 27, 2020, 03:51:58 pm »
Nice reuse of one of those horrible plastic packages.
I cobbled together something when I wanted to do some battery capacity measurements. I took a couple of bits of copper sheet, cut a bit off one side to form two ears for clipping wires to, for 4-wire measurements. From the offcuts I hammered the copper offcuts into dome-shapes and soldered them on so that they can make contact with batteries that have recessed ends. Some scrap carbon fibre angle and bolts glued on allow them to clip into the holes in my clamp, so they can be adjusted to hold any size of battery securely.
The following users thanked this post: mixiom
Offline JohanH
« Reply #7 on: August 27, 2020, 06:47:17 pm »
Had the same issue the other day with an A23 battery. Two terminals and an IC tube to the rescue.
Offline Daixiwen
  • Country: no
« Reply #8 on: August 28, 2020, 08:11:46 am »
wires and duct tape. works great too  ;D
Offline lwatts666
« Reply #9 on: August 28, 2020, 08:42:49 am »
I've been caught raiding the kid's Lego...
The following users thanked this post: Daixiwen
