Yep, and people always forget about the other fissionables, U and Pu are NOT the only things that could work if you do the sums.
I am somewhat surprised that Am241 is not more of an issue, you could wrap a reflector around a surprisingly small mass and get criticality by my back of an envelope, cannot be bothered to do the sums to see if it would work for a bomb, but a reactor looks workable to me.
I also wonder about (but again cannot be bothered to do the sums) a reactor using a two stage process, start with neutron bombardment of something that will capture the neutron and start a decay chain emitting a few alphas, then bombard beryllium with the alphas to make neutrons.... Probably tricky to get the losses low enough for criticality, but maybe, just maybe.
I wonder if there is something that can be hit with a neutron to get you to one of the Astatine isotopes, that would get you 3 alphas in the decay chain within a few minutes.
Hum, turns out that Bismuth can capture an alpha getting you onto the polonium chain, which would then give you two spare alphas from its decay chain, thats fun if the energies work out, not exactly what I had in mind, but interesting none the less!
Regards, Dan.
