Author Topic: FP6116 Asynchronous Step-Down Regulator  (Read 1454 times)
Offline JaneTopic starter
« on: June 23, 2014, 02:43:16 pm »
I have a Linux embeded board that  uses
a datasheet  is here
http://www.micro-bridge.com/data/Feeling-tech/FP6116.pdf
In this design , that Asynchronous Step-Down Regulator  should supply 1,2V for  CPU  on this board.
It worked for some time but now it stopped.
So, I measured voltage and that Asynchronous Step-Down Regulator  still supply 1.2V, yet CPU does not start.
But when I use a different source of 1.2V, the CPU starts.
So, I am rather confused.
I can measure the same voltages, and more or less the same spikes( using oscilloscope), yet different results.
Can anyone suggest any solution to that problem?
Thanks
